Okay, so i did the Map 0 log, however, I think my buddy messed it up when he was pulling the start log button but its there. I think switched to Map 6 with the settings you recommended to try. I set FOL to 70, 6cyl to 1, and boost safety to 20. I'm unsure how to/where to fix the ign issue you mentioned (im still new to the JB4 tuning). Also, earlier in the day, I did notice that around 800-1500 rpm my car vibrates a lot more as im accelerating, and disappears as it goes on, thought i'd mention this as it might be an exhaust leak. Finally, I read my codes because i have a CEL, and I had P010132 (could not find anything on it) and P0000. If you know anything about these codes it'd be great to know.
Map 0 Log: https://datazap.me/u/mygolfisslow/map-0-data-log?log=0&data=1-4
First Map 6 Pull: https://datazap.me/u/mygolfisslow/map-6-data-log-first-pull?log=0&data=1-4
Second Map 6 Pull: https://datazap.me/u/mygolfisslow/map-6-data-log-second-pull?log=0&data=1-4
1500 12
2000 13
2500 14
3000 15
3500 16.5
4000 16
4500 15.5
5000 15
5500 14.5
6000 14
6500 13.5
7000 12
try these settings as your IGN1 one is dipping, and report back ,we need to improve the ign1 timing.
Besides that you see if u enable IGN1 on datazap site it shows at 6k rpms your peaking 13.5 ign1(map 0) , higher octane will achieve higher timing. I understand your reasoning for 91 thou... but aim for 13.5 or better when your running your tune... As well map 6 log 1 shows dip around 4.8k rpms but recovers we want to remove that dip in ign1, by lowering boost.... map 6 log 2 u see a dip around 4.2k and recovers at 5k rpms, what you would do here is lower by 1 psi to see how it reacts.... and a timing advance of 12.5 at 6k rpms which is good were getting close.
u want peak psi to reach by 3.5k/4k rpm ... as the turbo looses efficiency at this point especially with lower octane.(Even higher octane you can only push so hard on this small turbo)
