Braille Battery GU1R 12v Lithium Ion Retrofit
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
I ordered this for my GTI after I saw your pic. I bought a Braille AGM 15 lb and the corresponding holder from Stable. So you just place it how you would a normal battery and the brackets fit without modification?
Fit the Stable around the battery which then makes it a "normal" size to fit like a normal battery into the OEM factory battery tray...:cool:
TecklenburgVW
Saint Cloud, FL
The Stable cage for the GU1R fits like that yes, however, I'm not familiar with the size of the cage for you're Braille AGM.
Sent from my SM-G920V using Tapatalk
mursepaolo
Hmm this is what I was afraid of since yours looks more like a standard size.
mursepaolo
Don't let my photo fool you. The GU1R is smaller than a standard size battery.
I figure as long as the bracket is able to fit around a corner of it, it should be fine right?
mursepaolo
With a Braille 15 lbs AGM, would there have to be any changes in habits? IE not sitting in car with engine off and stereo on, etc?
TecklenburgVW
Saint Cloud, FL
Just a quick PSA - a Braille G30 (replaced the GU1R) in its corresponding Stable cage does not work with the factory tray.
Thank you for the information; I wasn't aware that Braille discontinued the GU1R. I wonder if there are any GU1Rs in the market that are being sold with a discount?
I'll check summit racing later.
replicate
Downunder
No, I’m running a similar weight Fullriver AGM and I haven’t changed any habits. The stop start does not activate. That is the only difference. Just be smart and don’t sit for an hour draining the battery.
mursepaolo
Hey guys. I just finished installing the Braille 15 lb AGM and tried to do battery adaptation via OBD11 and it won't take it, showing error 31 function not available.
20ah
BRA
1111111110
Binary - AGM
That's what I entered, but no dice.
Any help?
Edit: Car ran fine yesterday. Is the coding absolutely necessary? Or is it only for cars with auto start/stop function?
amritdesai
New Mexico
GTI
Following up on the coding requirements for the lithium batteries.
I just purchased the G30 battery from Braille for my 2017 S - anyone have success doing the battery adaptation via OBD11? I don't have auto stop/star function on my car.
^Is the coding necessary?^
amritdesai
New Mexico
GTI
Coding as detailed in the previous post worked excellent with the OBD11.
13Ah
Bra
1111111111
Lithium ions
I had to play with the orientation of the battery/terminals. I ended up having to mount the cage on its side, directly to the battery tray with the supplied self tapping screws. No big deal honestly.
Love the upgrade so far! The stereo even sounds better:LOL:
