Some thoughts after installing and taking it for a spin...
Install was pretty straightforward. I positioned the JB on the edge of the battery tray, and ran the harness under my injen intake. Disconnecting the harness to position everything initially made this much easier. I may secure the JB to something using zip ties, as right now it's not tied down.
Plugs A B & C are really straightforward.
I actually spent like 15 minutes just looking for Plug D.. I was looking at the wrong section of piping initially
Once I had a grasp on the plumbing, I finally spotted D, under the A/C compressor. I don't know if anyone else had difficulty locating D, but maybe the instructions should be more clear as to where it's located. Or maybe I'm just a bit slow.
Removing D was actually pretty easy for me. I was able to do it one handed from the top of the engine bay. Getting the JB harness components onto D was a breeze after removing the stock plug.
I connected the unit to my Macbook using bootcamp into Windows 8 and installed the JB4 software using the link on the first page. It connected without issue, but I want to mention that the User Adjustment tab was slightly different than the one used for the tutorial on the first page of this thread. The "Boost Failsafe PSI" was referred to as something else, similar, but different enough that it took me a minute to figure out that that was the place to adjust the boost.
I set mine for 5psi. My only mod is the Injen intake but I have access to Shell 93, so I want to take advantage of it!!
Driving impressions:
When you're not in boost, the car drives exactly the same as stock, which is a good thing. My car is a daily driver, and I don't want to sacrifice drivability in any way. When pushed into boost... man, the car really comes to life!! The difference, to me, was dramatic compared to stock. Mid and high range really push you into your seat and keep you pinned until red line. So much so that the traction control light flashes sometimes in second and third.
Driving on the highway in 4th - 6th gear is so much more enjoyable now. The power is there waiting for you, and as soon as you step on it you'll almost immediately feel the torque that's on tap as you propel forward and pass other cars effortlessly.
One thing that's really important to mention is that the power delivery is completely smooth. Someone else mentioned that they could feel the unit trying to activate or something, but I noticed absolutely no hesitation or "transition" as the JB takes effect. You wouldn't know the JB was there based on the way it drives. It's silky smooth.
I'm very happy I waited for this unit. I'm looking forward to tinkering a bit more and mayyybe adding a downpipe to squeeze a bit more out of the car.
Nice work George.
