Right out of the box Map 1 is ready to go. I know that much.
4th gear is awesome lol just got done running her hard. I am using 93 octane with no bolt-ons so, tomorrow I am going to hook up the laptop and give it a little more boost.
Thanks for the update, sounds very promising indeed.
If you wouldn't mind, could you take some screenshots of the steps taken to play with the boost settings? There are a lot of fields on the interface, would like to see what all the other numbers look like.
Do you have any plans on putting her on a dyno to measure HP/TQ against AFR?
Thanks man.
Map 1 is ready to go without needing the cable. The base map setting is +4.75psi and its suitable on the S3 to run on 91. You going to want to increase this too +5.25 when you run 93 and see how the car feels, if you feel it hanging slightly at the top just lower it slightly. This is preferred so the car can run consistently during the heat of the day and night.
Once map two is released you can run the setting we going to recommend at the time for the more aggressive curve with 91. Again you can work with the psi even in map 2 to what is suitable to 91 and 93.
The reason the JB4 has not been released is I decided to rather do a completed unit without the need of the add on's we saw on the N54. I like to do things systematic and the last thing I want is to expect someone to evolve via the development stages knowing each step that happened in the years that went past. The great thing is that most the work has been done on the BMW's so its basically piggy backing on that platform.
I have screenshots on page 1, not sure if everyone can see them?
Again, music... sounds to me like those with access to 93 octane / 98 ron will have a choice between Map 1 and Map 2, the difference being the tweaking of boost levels to suit.
Have you got any graphs showing AFRs from your testing & development? I assume the JB has the ability to influence not just Boost & Timing, but also Air/Fuel?
