255's are the way to go. still trying to extract every millimeter of wear outta last seasons nitto nt05'sGetting it dialed in with the new 255s
Nice wheels, got the same set. What are the specs?255's are the way to go. still trying to extract every millimeter of wear outta last seasons nitto nt05's
17x9 +45 w/5mm spacers 255/40/17 Nitto nt05. on coilovers as well.Nice wheels, got the same set. What are the specs?
I was using the same tires at Lime rock last week. The felt good, although grip falls off after about 15 minutes. I did experience a lot of front tire wear, although that may have been the fault of my driving style.17x9 +45 w/5mm spacers 255/40/17 Nitto nt05. on coilovers as well.
swapping the Nitto's for Accellera 651's (same specs) as soon as the weather gets a little nicer. a set of 4 tires with tax only cost me $375 shipped to my front door. the reviews on the 651's are really, really good!. if anyone is looking for a good extreme performance summer tire for low $ they're gonna be your best bet.
the accerelra's? it seems like its really hard to find an optimal tire for under $200 a corner for hard core track use. i have high hopes for them however, i need a dual use summer tire atm and that fact is always gonna have limiting factors. unfortunately my car see's more back roads and car meets than track days. i need to do something about changing that. however i am super excited to be going to my first wookies.I was using the same tires at Lime rock last week. The felt good, although grip falls off after about 15 minutes. I did experience a lot of front tire wear, although that may have been the fault of my driving style.
Yes, i have the acceleras in 200tw. For the price, I'm impressed. However, they do make a lot of noise while driving in the highway. For dual use you might be better served by a 300TW.the accerelra's? it seems like its really hard to find an optimal tire for under $200 a corner for hard core track use. i have high hopes for them however, i need a dual use summer tire atm and that fact is always gonna have limiting factors. unfortunately my car see's more back roads and car meets than track days. i need to do something about changing that. however i am super excited to be going to my first wookies.
It’s always funny to read this...35 sidewall though... Rubber band territory.
The 35 is a aspect ratio number, therefore its height changes based on the width of the tire, to blanket say “a 35 aspect sidewall is smaller than a 40,45, etc” is incorrect.
Simply put - the 35,40,45 is a percentage based on the width of said tire so it changes.
Factory tire on a GTI is 225/40/18, at 255/35/18 is 2mm shorter, completely negligible.
It's based on the cross section:I always thought the 35, 40, or 45 was the height of the tire from the rims lip, regardless how wide the tire is.
Aspect Ratio
Is the ratio of the height of the tire's cross-section to its width. The two-digit number after the slash mark in a tire size is the aspect ratio. For example, in a size P215/65 R15 tire, the 65 means that the height is equal to 65% of the tire's width. The bigger the aspect ratio, the bigger the tire's sidewall will be.
https://www.goodyearautoservice.com/en-US/tire-basics/tire-size#:~:text=The two-digit number after,the tire's sidewall will be.
Yes, in theory - But you still need to take tire cross section width into consideration. If we wanted to compare two extremes to highlight this we could compare a 125/65R18 vs 295/45R1812 where the latter is taller from rim to tire end:That's what I was getting at. The bigger the number, the bigger the sidewall will be and vice versa.
