El_bigote_AJ
- Las Vegas
- 2019 GTI bunny
Is this not on the first revision from the base file ?The problem is it is far from target and once he gets his new DSG file to run to 7k it will most likely start to break up. It's at mid 12s at 6500. It will be worse at 7k. Can't even see what boost it is even running. Also runs several psi less in the 4k region than EQT. It could use another revision.
That tune was requesting it to run 40.5 PUT, and still topping out past the reading - looks like he’s just still needs to request even lower since Jon’s setup is working extra efficiently
