The EQT MPI tunes use closed loop lowside fuel pressure control. The pump only runs long enough to hit whatever the programmed desired lowside fuel pressure is, not x seconds or whatever like it is stock. The MPI fuel pressure sensor lets you enable this neat feature built into the ECU.
Not necessarily EQT related, but rather closed vs open loop.
Would this be the reason why LFP requested vs actual don't follow?
Meaning. stock FPC requested @ idle is 5 bar, actual is usually +/- 0.5 bar
This may/may not be the case for a stock FPC+525 LPFP tune as well, but my RS3 LPFP idles at 3.6 bar +/- 0.1 bar without any inclination to chase requested.
