5G0 035 456 - Component Protection
aqxavier
Brasil
Hi,
I'm having trouble with an amplifier unit that I bought to replace the one that had on my golf mk7(5G0 035 456).
It is not being activated because the active component protection in the Can Gateway.
I saw that it is necessary to make the virgin unit again for it to be active.
How can I perform this procedure?
Regards,
Alexandre
DV52
Australia
Hi,
Regards,
Alexandre
aquavier: Hi Not sure how familiar you are with component protection on MQB platform vehicles, so please forgive me if I'm telling you something that you already know.
From my reading of VW's literature, I understand that all control units on the MOST150 ( (150 MBit/s) ring topology participate in component protection.
So J525, the digital sound package control unit (the "amplifier') will be captured in the surveillance network.
Here's an extract from the SSP about CP:
The component protection master used is the data bus diagnostic interface J533. Following replacement, control units with component protection must be enabled online by FAZIT, or the control unit will be restricted in function or will not work at all. A component protection comparison is usually performed by the diagnostic interface for every terminal 15-ON cycle, and the validity of the installation is checked. If it is determined that a known constellation of devices is working in the same way as during the last driving cycle, then the control units are enabled for regular functions. If this is not the case for a control unit, then the component protection is activated in this control unit, which has an impact on its function.
Here is the list of control modules that are included in VW's constellation for CP
J234 Airbag control unit
J285 Control unit in dash panel insert
J428 Adaptive cruise control unit
J519 On-board power supply control unit
J533 Data bus diagnosis interface
J685 Display unit for front information display and operating unit control unit
J794 Control unit 1 for information electronics
J525 Digital Sound Package control unit
R78 TV tuner
R Radio
As indicated in the SSP, the only way to remove a CP error is via FAZIT connection which is available through a registered VW dealer (to guard against recycling stolen units). albeit I'm aware that a VCP cable may be able to do it too.
Cheers
Don
aqxavier
Brasil
Hi DV52,
I managed go on a CSS in São Paulo to remove the component protection and sound again function normally. :)
I'm having other difficulties and do not know if you ever had this experience ..
Golf My Own Park Assist and Park Pilot.
Once we installed the MIB 2 rear camera no longer works (it opens normally but does not show the image MIB)
ParkPilot also no longer opens.
I did a scan and found these errors ...
You tell me who are these errors and how to reset them?
I sending herewith also the map of adaptations that is active at the moment.
---xxx----
Error in 5F:
8S0035049 J794 MU-H-LN-CN 027300030000000011110002000808101F0203B401200100FE 0343
Errors found
1586($000632):09 (B200500) Data record invalid Break / short to ground. Lamp OFF Status unknowm
1588($000634):09 (B200500) Data record invalid Break / short to ground. Lamp OFF Status unknowm
1589($000635):09 (B200500) Data record invalid Break / short to ground. Lamp OFF Status unknowm
1595($00063B):09 (B200500) Data record invalid Break / short to ground. Lamp OFF Status unknowm
1652($000674):09 (B200500) Data record invalid Break / short to ground. Lamp OFF Status unknowm
1598($00063E):09 (B201200) Data set implausible Break / short to ground. Lamp OFF Status unknowm
1556($000614):09 (B200087) Control module Software incompatible Break / short to ground. Lamp OFF Status unknowm
2571($000A0B):09 (B126CF2) Navigation system Navigation database not enabled Break / short to ground. Lamp OFF Status unknowm
3073($000C01):09 (B105313) GSM antenna Open circuit Break / short to ground. Lamp OFF Status unknowm
7179($001C0B):09 (U111100) Function limitation due to missing message Break / short to ground. Lamp OFF Status unknowm
7226($001C3A):09 (U111100) Function limitation due to missing message Break / short to ground. Lamp OFF Status unknowm
Error in A5:
5Q0980653F R242 MQB_MFK 0101020000020303000400000100000100 0052
Errors found 2555904($270000):09 (U112100) Databus missing message Break / short to ground. Lamp OFF Status unknowm
Regards,
Alexandre
  • adpmap-5f-8S0-035-049_MIB2.pdf
Jack'o
Poland
Hi Alexandre, Hi Don - I have installed MIB2 DP, MIB1 DP was previously.
I logged also fault message on A5 module after remove to MIB2 unit.
Code:
A5 Front Sensors Driver Assistance System
    Software number: 5Q0980653E
    Software version: 0050
    Hardware version: H05
    Trouble codes:
        U112100 - Databus missing message
            static
My A5 unit is "E" SW0050, Alexandre unit was "F" SW 0052 and as we see those unit doesn't support MIB2 units.
Do you know how fix this problem? Should be change coding of A5 unit for MIB2?
Greetings! Jacko
Jack'o
Poland
Error in A5:
@aqxavier - did you find solution?
Flash unit to SW0060??? Or just change camera to "5Q0980653G" needed?
jethrosf
San Francisco
5G0-035-456 Direct Replacement
Does anyone know if I can just order a salvaged 5G0-035-456 Amp only and replace it without having to do any VAG work? I have a 2015 GTI Autobahn with the Fender system.
