Hi DV52,
I managed go on a CSS in São Paulo to remove the component protection and sound again function normally.
I'm having other difficulties and do not know if you ever had this experience ..
Golf My Own Park Assist and Park Pilot.
Once we installed the MIB 2 rear camera no longer works (it opens normally but does not show the image MIB)
ParkPilot also no longer opens.
I did a scan and found these errors ...
You tell me who are these errors and how to reset them?
I sending herewith also the map of adaptations that is active at the moment.
---xxx----
Error in 5F:
8S0035049 J794 MU-H-LN-CN 027300030000000011110002000808101F0203B401200100FE 0343
Errors found
1586($000632):09 (B200500) Data record invalid Break / short to ground. Lamp OFF Status unknowm
1588($000634):09 (B200500) Data record invalid Break / short to ground. Lamp OFF Status unknowm
1589($000635):09 (B200500) Data record invalid Break / short to ground. Lamp OFF Status unknowm
1595($00063B):09 (B200500) Data record invalid Break / short to ground. Lamp OFF Status unknowm
1652($000674):09 (B200500) Data record invalid Break / short to ground. Lamp OFF Status unknowm
1598($00063E):09 (B201200) Data set implausible Break / short to ground. Lamp OFF Status unknowm
1556($000614):09 (B200087) Control module Software incompatible Break / short to ground. Lamp OFF Status unknowm
2571($000A0B):09 (B126CF2) Navigation system Navigation database not enabled Break / short to ground. Lamp OFF Status unknowm
3073($000C01):09 (B105313) GSM antenna Open circuit Break / short to ground. Lamp OFF Status unknowm
7179($001C0B):09 (U111100) Function limitation due to missing message Break / short to ground. Lamp OFF Status unknowm
7226($001C3A):09 (U111100) Function limitation due to missing message Break / short to ground. Lamp OFF Status unknowm
Error in A5:
5Q0980653F R242 MQB_MFK 0101020000020303000400000100000100 0052
Errors found 2555904($270000):09 (U112100) Databus missing message Break / short to ground. Lamp OFF Status unknowm
Regards,
Alexandre
