SAABTurboGuy
- NY
Hi folks, curious if anyone has any ideas. Was on trip from NY to Vermont, and the car died. Quick synopsis.
Cruising along as normal, all of a sudden, shaking, misfires, CEL/EPC light flashing, no power. Engine eventually dies. Can't restart.
Car gets towed to dealer in Massachusetts. I was in bay with technician.
They can't even crank it.
Codes for misfire and fuel pump short. No timing related codes.
Technician can't even manually turn the engine.
Tried to remove spark plugs, got 3 of them out, #1 is stuck after a few turns. I'm quite sure I didn't cross thread when I put them on 2 years ago. Tech doesn't want to force it, waiting for foreman to return next week for his opinion.
Tech noted fuel pump was messed with...it indeed was... suction pump recall done by my local dealer under warranty way back when. Tech said connector for wire was broken and wiring was sloppy.
Oil level fine.
Recent background - had slightly bent fingers on clutch pressure plate a few months ago with no identified cause. Possible clue the crankshaft wasn't quite right? But then I also have this fuel pump code. No check engine lights prior to this acute event.
Tech thinks something definitely up with cylinder #1, maybe causing the plug to be stuck? Fuel pump maybe spazzed out and cylinder 1 had some kind of major detonation event?
Today I return to NY, leaving the car in Massachusetts. Pretty ridiculous a stock car, driven gently, maintained religiously, would self destruct cruising on the highway with 80k miles.
Any thoughts at all on what could have happened?
Do I let the dealer try to the that spark plug out? They said they run the risk of ruining the threads in the head and that they will only do it if I'm sure I'm comfortable with it. We'll see if the foreman has any other ideas.
Thanks so much! Really stressed over this, ruined our vacation and may ruin is financially.
Oil level fine.
