I've been doing some boost-centric testing in the top end - it is doing just fine, based on the actuator readings:
https://datazap.me/u/jybyrd4606/is38-01-9028-27-tpr-4th-gear?log=2&data=1-4-6-7-17-18-19-20-21
I know the timing is low... ignore that for now. Trying to dial in the boost before monkeying with timing. It is carrying 23/24psi all the way through the RPM range. I'm going to bump it up again to 25psi target and see how that works out.
This is pretty close to the max redline boost I will run on the hybrid. On track to dyno by the end of the month.
Is anyone considering this path, and wanting more peak boost than 25psi? I'm willing to jack it up to about 27psi target and run a few logs, but won't do it if there isn't any interest.
