EventhorizoN VW GTI S build
eventhorizon
Los Angeles, Ca
Jun-26-2021-Speed SF (Sat) [[a846d507a2]] -- Session 1 (Sweeper) - BW3_7023_Jun2621_905AM_.jpg
Hello fellow Golf MK7 members, just around a month ago I bought a used Reflex Silver 2017 GTI S 6 Speed Non PP (16,000 odometer miles) at date of purchase.
Other build Audi S4 B8.5
Current Car:
2017 Volkswagen GTI S Non-PP
Current Power Output
: 500whp on E85 | 460 Whp on 91 pumpgas
Current modifications and Enhancements:
__________________________________________________ __________________________________________________ __________________________________________________ ________________
Interior:
CAE Ultrashifter for MK7
https://cae-racing.de/CAE-Ultra-Shifter_3231
BFI Heavy Weight Shift Knob SCHWARZ Red Alcantara https://www.uspmotorsports.com/GS2SRU.html
OEM GTI Clubsport S Alcantara https://www.ecstuning.com/b-genuine...sport-steering-wheel-manual/5g0419091egnnm~o/
Vent Gauge Pod for Air/Fuel Ratio
European Spec GTI Clubsport S alcantara Steering Wheel
ECU:
Equilibrium Tuning Protune on Cobb Accessport for EQT Vortex on E85/91 octane. Performed by Ed
EVO Series Digital Wideband Air Fuel Gauge Kit
- 10.0:1 To 20.0:1 AFR https://www.ecstuning.com/b-prospor...-gauge-kit-1001-to-2001-afr/216evoafrwb4.9~p/
PM4 Fuel Control Module: https://torqbyte.com/products/vag-pm4-high-power-fuel-pump-control-module
______________________________________________________________________________________________________________________________________________________________________
Engine and Drive-train:
Installation of Parts performed by: JMP Autowerkz in Canoga Park, Ca. JMP Racing Founder Jerick Javier
Full Integrated Engineering Long Block Crate Engine (First Engine Crank-walked)
-IE Tuscan I beam connecting rods
-IE Spec Mahle 83mm bore 9.3:1 forged pistons
-Mahle race rod bearings
-OEM new main bolts & thrust washers
-OEM new main bearings
-IE Valve Springs and Retainers
-IE Valve Guides
-Ferrea Valves
-IE Valve Seals
-IE Valve Keepers
-Performance Valve Job
Engine Installed and Assembled by Jerick Javier at JMP Autowerkz in Canoga Park, Ca
EQT Vortex Turbo https://eqtuning.com/products/eqt-vortex-turbocharger
IE Cast metal downpipe with high flow catalytic converter https://performancebyie.com/products/ie-downpipe-vw-audi-20t-tsi-mk7-awd
IE Sheet Metal Intake V2 with carbon fiber lid https://performancebyie.com/products/ie-intake-vw-mk7-audi-8v-tsi
Revo Intercooler Pipe Upgrade https://www.onlyrevo.com/product-details/cooling/mqb-chassis-intercooler-pipe-upgrade&engineid=182
APR Turbo Inlet https://www.goapr.com/products/turbo_inlet_pipe_20t_mqb.html
gclid=CjwKCAjwuO3cBRAyEiwAzOxKshUQnHxgRm7r73WgLC_FLJH4PoQRishvD0eMeDct38zUgYsro6yMqxoCyNEQAvD_BwE
Fluidamper Harmonic Damper Crankshaft Pulley https://www.ecstuning.com/b-fluidampr-parts/harmonic-damper-crankshaft-pulley/551231~flu/
Forge Performance Turbo Muffler Delete https://www.ecstuning.com/b-forge-p...oHkdPqNSd_l2PX4J-_IWS6lw5VlS2eSAaAkwCEALw_wcB
Forge Performance Blow Off Valve https://www.ecstuning.com/b-forge-p...Hm5l_NZsjFLxbHAS3SLenH6-CEG3mHZBoClWcQAvD_BwE
Audi RS3 Upgrade Coil Pack Kit for MQB https://www.uspmotorsports.com/Audi...nbAVYwB8766nCj9W6gyqFZ3YJlDOba6RoC6_gQAvD_BwE
Denso Iridium IKH24 spark plugs https://www.ecstuning.com/b-denso-p...8aUAEZzvgtI5JKoRwI4ItIuJdARQSYSxoCOKEQAvD_BwE
Wavetrac Limited Slip Differential https://www.ecstuning.com/b-wavetrac-parts/front-limited-slip-differential/10309175wk~wvt/
HS Tuning RSR Clutch with OEM Flywheel https://www.hstuning.com/hs-tuning-...CBkG6_8i3XkBJX7JwLrS5lqU7I9dIPqWZN67JrAeSwiUE
Autotech High Volume Fuel Pump Upgrade Kit Gen3 TSI https://autotech.com/new-products/autotech-high-volume-fuel-pump-gen-3-tsi-tfsi.html
Engine Cooling
APR MBQ Front Mount Intercooler Kit https://www.goapr.com/products/intercooler_ea888_mqb.html
Gen3 TSI Oil Cooler Adapter Plate Kit https://www.ecstuning.com/b-iabed-i...3-06l-oil-cooler-feed-plate/462-635-0010~iab/
Mishimoto Oil Cooler 19 Row https://www.ecstuning.com/b-mishimoto-parts/universal-oil-cooler-19-row/mmocul~msh/
Cool Flow Aluminum Oil Filter Housing https://www.uspmotorsports.com/Cool...pJ_zxYo8G2mw-kpdLbfoQSEjI9eO3cGBoCt6sQAvD_BwE
AEM 1 Gallon Water/Methanol Injection Kit- Multi Input Injection https://www.uspmotorsports.com/1-Gallon-Water-Methanol-Injection-Kit.html
VWR Racingline Oil Catch Can https://www.ecstuning.com/b-racingline-parts/vwr-oil-catch-tank-oil-management-kit/vwr13g700~vwr/
Fluids:
Motul 660 Competition Brake Fluid
Motul 300v Racing Oil
Motul Gear Racing transmission Oil 300
Only run Motul since purchase of vehicle.
Suspension:
Race Spec Alignment by Robert Che of Chewerkz
NEUSPEED Race Series Rear Anti-Sway Bar - 27MM
https://www.uspmotorsports.com/2502275-7422.html
Whiteline Sway Bar Links front and rear with lateral locks
JRZ RS PRO Suspension with External Reservoirs
https://www.tyrolsport.com/suspension/chassis/jrz-rs-pro-suspension-system-8v-a3/s3/
Track alignment and corner-balancing
Exhaust System:
STREET SETUP: OEM GTI Clubsport S Axle Back Exhaust System 2.5" exit
https://www.ebay.com/itm/Genuine-VW...-Rear-Silencer-2013-5G6253609DD-/192258438421
RACE SETUP: AWE Tuning Track Edition Catback Diamond Black Tips https://www.uspmotorsports.com/AWE-Tuning-VW-MK7-GTI-Track-Edition-Exhaust-Diamond-Black-Tips.html
Integrated Engineering Catted Downpipe 3" https://performancebyie.com/products/ie-downpipe-vw-audi-20t-tsi-mk7-awd
SILCENCER: Vibrant Performance 3"x12" resonator for sound dampening https://www.summitracing.com/parts/...GZqrxnnACI9nLGe-arjrhA47M34KqLmsaAqOzEALw_wcB
Wheels:
Advan Racing TC-4
Racing Gunmetal 18"x8.5" on
Bridgestone RE-71R 255/35/18
Aerodynamics and Exterior:
Premium DeutschCarbon v2 Hood (not installed)
https://premiumdeutschcarbon.com/product/mk7-premium-vented-hood-level-2/
Custom Splitter by Racebred Components / with quick release chassis mounts
ECS Tuning Rear Wing
(Carbon Fiber) Painted http://www.voomeran.jp/product/golf7/roof_wing.html
Versus Engineering Rear Diffuser for GTI https://www.verus-engineering.com/product-page/rear-diffuser-golf-r-mk7
Razor 7 Front Lower Canards (Carbon Fiber) http://www.revozport.com/product/golf-razor/r7-canard
Versus Engineering Upper Canards (Carbon Fiber) http://wctperformance.com/verus-engineering-dive-plane-canard-kit-golf-r-mk7/
Helix Golf R headlights (clear corners and reflectors); with Mishimoto HID headlight kit
ECS Tuning Side Skirt extensions
Braking:
Front: Custom AP Racing Radi-CAL BBK Front 4-Piston / Chicane Pattern https://www.stillen.com/catalog/pro...ke-kit-red-calipers-apr34410sr/category/1594/
Rear: Performance Pack 310mm Stoptech Performance Pack Slotted Rear Brakes Rotors, EBC Performance Pack Red Stuff Rear Brake Pads (310 x 22mm) https://www.shopdap.com/performance...de-rear-brake-kit-for-mk7-gti-310-x-22mm.html
Stoptech rear brake lines streel-braided racing.
The day I picked her up:
eventhorizon
Los Angeles, Ca
In case some of you guys are interested, here are some pictures of my Audi S4 B8 build.
ECS Tuning Aero: European RS4 front grille and Fog lights, Front Splitter, Rear Diffuser, Carbon Rear Duck bill wing. APR Stage 2 Tune, APR Crank and Supercharger Pulley, Advan GT 19x9.5+40 offset custom wheels, JRZ RS One Suspension, ECS Tuning Cold Air Carbon Intake, Michelin Pilot Sport PS4 Tires, AWE Track Edition Exhaust, AMS Front Mounted Intercooler, APR DSG Tune, Ultracharger, Mishimoto Oil Cooler, and many more.
Thanks for looking~!
eventhorizon
Los Angeles, Ca
Nice builds! Go stuff so far. Cheers!
Thank you for the warm welcome man!
For now here is a close-up on my 19x9.5 +40 Advan GT (Hyper Racing Black), going to get the Voomeran Over-Fender Flare kit to fit these on my GTI.
eventhorizon
Los Angeles, Ca
quick update: I received my Flow Designs front Splitter and Craven-speed front license plate relocater this weekend! I'll be sharing the splitter once it's mounted on. The license plate holder is a beautiful construction.
eventhorizon
Los Angeles, Ca
Just finished installing the AWE Tuning Track Edition Exhaust with Black tips. I'm really happy with the finish quality and performance. If anyone is interested, I'll post some sound clips. It's not droning or loud to be honest. Very happy indeed!
eventhorizon
Los Angeles, Ca
Super excited today I ordered a Black Forest Industries Stage 3 Clutch Kit
In addition, I ordered the Wavetrac Limited Slip Differential ~
can't wait to install these parts so I can start doing some real power modifications.
Can Anyone here recommend a good front and rear brake kit that will aggressively fit 18" size wheels?
tpellegr
Boston, MA
2016 GTI S 6MT
I'm thinking about going w the same exhaust (w AWEs DP)! Let us know how you like it as it breaks in. Great build so far.
Sent from my Pixel 2 XL using Tapatalk
eventhorizon
Los Angeles, Ca
It's been a full weekend of driving the GTI and I'm very happy with the performance from the AWE track edition exhaust. It sounds better and better as I drive and break it in. I love the idea of adding a catted downpipe as well. I'm thinking of going Cobb for mine. Keep me posted on your build bro! Thanks for the kind message ;)
Square1
Toronto
Those mods all compliment the car really nicely and you are going to love the wavetrac diff, the bfi clutch pack not so much. I hope you have a better experience than I did/do.
The downpipe will make the AWE exhaust scream amazingly.
Sent from my SM-G930W8 using Tapatalk
eventhorizon
Los Angeles, Ca
Hey man! thanks for the encouragement bro~! What was your experience with the BFI Clutch? Which clutch would you recommend? Also what Downpipe are you running? Thanks in advance~
Jarbear
SF Bay Area
2024 RS3
Nice!! Question. Do you plan on upgrading brakes as well? As you are planning on installing a beefier clutch and wavetrac for what one can only assume more power is in your future.
eventhorizon
Los Angeles, Ca
Yes absolutely need to upgrade my braking to something that can fit aggressively in an 18" wheel. Looking for recommendations?! My budget for brakes front and rear are 2k
sprinks
United States
For 2k, you could look at piecing together a TTRS brake setup, 340mm rotors of your choice, and then swap up to the performance pack rear setup. If you want to stay oem, of course. Alternatively, save some bones, get the porsche boxster caliper adapters, run on 312 rotors as is with a great selection of pads out there.
Jarbear
SF Bay Area
2024 RS3
2k opens up a lot of possibilities. As Sprinks said, TTRS is a good choice w/ the PP 340mm rotor. Check out Vagbremtechnic as they have a few kits. The stoptech ST-40 is also something to consider.
