tplociniak
- NEPA
- 2017 Alltrack SEL
Anyone have a good starting point for map 6 settings with an is38 swap, stock downpipe?
Any issues make mating the stock DP to the IS38? How does it feel? Did you ever have a IS20 on the car?here is the first log of my alltrack after the is38 swap, 93 octane, stock alltrack dp, running map 2 on the jb4
https://datazap.me/u/tplociniak/alltrack-is38-map-2-stock-dp-61-outside-air-temp?log=0&data=1-4
Billy has worked on my car also. Curious to see how the car feels dialed in compared to the IS20.I had the is38 installed by a shop, A2B motorsports, he didn't mention any issues during install and there are none now.
It doesn't feel as snappy as the is12 did on the same tune but it feels so much stronger. I really can't wait to get some direction from George to start turning up the boost.
I had an is20 on the car for only a few thousand miles and that was about a year ago. That felt awesome as I was getting that dialed in so I'm really excited to see what the is38 feels like.
Second log after the IS38 swap, stock dp, 18 psi max, 93 octane, 61* outside
https://datazap.me/u/tplociniak/alltrack-is38-18-psi-61-outside-temp?log=0&data=1-4
Pricing?OT alert!
Girls and boys, just wondering if any of you would like some no-tap AFR harness adapters, have some that will be ready in the coming weeks below! PM me
https://www.golfmk7.com/forums/showthread.php?t=51718
tplo, your log looks pretty good. Your ign-1 timing is sweet. My only question is can you get more boost? My is12 hits 19psi, so I gotta imagine your is38 has more headroom. But your Trims are pushing 44, so maybe adjust the FOL to 70? Your AFR looks good at 13.3, so I don’t know if is the fuel lean.
I’ve heard IS38s hit 25-26psi, but there are a bunch of factors involved including higher FOL and e85 mix. But since it doesn’t look like you have any major issues, see if you can set FOL to 70 or 75 and raise your peak to 20psi, with the same tapering.
Edit: Although your outside temps are 61*, which would be why your boost is lower, your IATs start in the mid 80s and go up to 105. Looks like you did a few runs and are seeing some minor heat soak. Someone else with cooler weather experience should chime in.
