I just looked at the OBD11 screen, there are two options, the basic setting, that I have done seven times in the past, and the “ calibration of synchro points”.
I never did that one, but guess I can try that one now. Do you know if it’s OK to do one without the other? Or am I supposed to do one, then the other?
I’m thinking that maybe I should also try the dynamic start assistant, and set it too “early”, to see if that maybe helps. I’m not sure if that eliminates the creep function, so when I let go of the brake, it won’t move until I give the car throttle. If so, that will probably fix the problem. I like it better that way anyway. I’m used to it because my other double clutch transmission cars don’t creep when I let go of the brake. They drive more like manual transmissions, which I prefer.
