gti330ex
- Chicagoland
Drew - what is your capable of 0-60 on the street?
Same boat here... I have access to E but just don't want to mess with it. With the is38, why would you need to add the HPFP unless EQT (I assume) comes back and says it's maxing out? Are there serious reliability concerns running E30-E50 on an is38? That would probably be near Vortex power on 93.I'm glad this is a topic because I've been back and forth a million times on my build.
Originally I wasn't going to mess with E. I can get it, but it's not plentiful where I live and I'd have to plan around fill ups. Which I'm not above doing, but it's not ideal. FCP Euro is38 and HPFP and aim for mid to upper 300's was the plan but if with the same fueling on a Vortex I can expect roughly 400 without popping, I might go that route. It's an $800 difference for a car that may never see a track and is my daily (I have a Jeep as a backup) but fast cars are fun. No interest in fueling upgrades beyond the HPFP internals, which are identical to my old Speed3.
For reference I have Vortex XL with HPFP on 93 running an 8.88 60-130 for over 30k miles no issues. I don't think an E85 IS38 will touch that but I could be wrong.Same boat here... I have access to E but just don't want to mess with it. With the is38, why would you need to add the HPFP unless EQT (I assume) comes back and says it's maxing out? Are there serious reliability concerns running E30-E50 on an is38? That would probably be near Vortex power on 93.
At the end of the day, I'm leaning towards the is38 on 93 AKI. It's the most simple, least costly, and most reliable option (and lifetime warranty), but I'm concerned it's not going to be a jump in power worthwhile coming from stage 2 93 AKI. Of course, the other option is Votex on 93 AKI with plenty of power, but it doesn't come cheap, and requires fueling mods which I hoped to never get in to.
The IS38 on 93 will put you into the 365 HP range with a good protune.Same boat here... I have access to E but just don't want to mess with it. With the is38, why would you need to add the HPFP unless EQT (I assume) comes back and says it's maxing out? Are there serious reliability concerns running E30-E50 on an is38? That would probably be near Vortex power on 93.
You're right. The IS38 will be down in HP compared to yours. By around 70 HP on E85.For reference I have Vortex XL with HPFP on 93 running an 8.88 60-130 for over 30k miles no issues. I don't think an E85 IS38 will touch that but I could be wrong.
Did you end up going is38? I’m thinking of doing the same as you were and interested in your thoughts.That's my plan come springtime. I don't want to dick around with fueling, and no E close by. Closest I know of is half an hour away. Stay with stock fueling, put on an IS38, and grab an EQT pro tune.
What steered you to vortex vs. is38?Not yet. Ended up sinking my money in other things for the car first. Currently, plan on going with the Vortex when I do swap the turbo.
That's a wise choice and I wish I would have done that for exactly the reason you said. With the IS38 you would have been around 365 HP on 91 octane and with the Vortex you'll be around 440 HP.I don't want to spend the money and go "That's it?" and be disappointed.
Any reason you went for the XL turbo over standard vortex? You sure are putting down big hp numbers.For reference I have Vortex XL with HPFP on 93 running an 8.88 60-130 for over 30k miles no issues. I don't think an E85 IS38 will touch that but I could be wrong.
A few actually.Any reason you went for the XL turbo over standard vortex? You sure are putting down big hp numbers.
So you’ll do autotech HPFP and a pump gas tune?I don't want to spend the money and go "That's it?" and be disappointed.
