anotero
Hither and thither
Mk7 GTI
Did a brake fluid flush. Used a Motive power bleeder. Followed the service manual.
Is it normal that i didn't have any air bubbles come out from my calipers?
OldVWFan
NW Arkansas
17 GTI Sport
If you did not open the system then you are just displacing old fluid with new, so you would not see air bubbles at the caliper bleeders. I have done this several times on my Mk VII GTI using the same power bleeder and have only had air when I replaced the brake lines.
CaptainRatty
Winston-Salem, NC
MK7 GTI
Can you post a pic of the front wheel well? I want ti make sure that there will be no fitment issues with my RallyArmor mud flaps.
Thanks!
I don’t think you’ll have any issues.
anotero
Hither and thither
Mk7 GTI
I opened the brake fluid reservoir and attached to it the power bleeder filled with two liters of brake fluid. Then tightened everything, pressurized the power bleeder, and bled the calipers. This is my first time doing it, so not completely sure what to expect.
akimmel
Ipswich, MA
2015 GTI AB 6MT
yeah if you haven't replaced a caliper or something, all you need to look for is the color/condition of the fluid coming through. You want it to look clean like the stuff fresh from the bottle, not dingy or dark yellow.
anotero
Hither and thither
Mk7 GTI
Great. I compared the color and by the end the fluid coming out wasn't cloudy.
anotero
Hither and thither
Mk7 GTI
Question about post bleeding per the service manual:
Am i correct in assuming that the power bleeder must be filled with brake fluid just like during regular bleeding?
Wastegate13
SoFla
Started it to find my fuel line leaking again. Anyone upgrade or change the routing on their cts mpi kit? If I can get a definitive answer on what size the plug in the rail is I’d like to route the lines how pr does.
YamR1rider
Tampa, FL
2017 GTI Sport DSG
That just seems to be a confirmatory manual bleed, not really even worth hooking the power bleeder up for. I'd just do it without the old way and make sure the fluid reservoir stays topped up. But yes, if you did hook up power bleeder, you'd need enough fluid in it to cover the process.
But are you finding your pedal a bit spongey after using the power bleeder? If not, no need to do this step at all.
anotero
Hither and thither
Mk7 GTI
My pedal seems a bit softer and longer now that i bled the brakes, hence my interest in the post bleed.
