About 13.9 freedom units boysManaged to fill record 52,6l of petrol to Mk7.5 combi which is ca. 2.6 above specs. For non-continental VWolks, please convert to a type of gallons you prefer![]()
It’s full fullRIP that LPFP
It’s full full
I'm lost lost.It’s full full
Pretty much. As soon as I’m a 1/3 full I pump gas. I don’t want to stress the lpfpIt was empty to take that much to fill it though
I can’t prove that this is truly a thing or an old wives tale. But apparently u don’t want to go below an 1/8 tank of gas due to added stress on the in tank low pressure fuel pump. As a result, our metric using brother got almost 14 gallons in on a fill up. If the old wives tale is true, it’s bad for the in tank pump.I'm lost lost.![]()
Not a wives tale. Fuel cools the pump, consistently running it low can shorten the life of the pump.I can’t prove that this is truly a thing or an old wives tale. But apparently u don’t want to go below an 1/8 tank of gas due to added stress on the in tank low pressure fuel pump. As a result, our metric using brother got almost 14 gallons in on a fill up. If the old wives tale is true, it’s bad for the in tank pump.
most I’ve ever pumped was maybe 7-8 gallons. I’d run my flex fuel Wrx to a 1/4 tank occasionally because I was gonna fill up with e85. But I’d never go lower than that
Sorry about that. I wasn’t too sure. ThnxNot a wives tale. Fuel cools the pump, consistently running it low can shorten the life of the pump.
U work fast!
U work fast!![]()
