Chillout
- the Netherlands
- SEAT Leon FR ST
Performance Monitor for Android Auto info topic
Hi all,
I'm building an app for use with Android Auto, that is capable of displaying car sensor data:
It has a lot of data elements available. This topic has a lot of progress talk, and questions being answered.
DO NOT UPDATE TO ANDROID AUTO V3! Custom Apps will NOT work.
Download:
Download the latest release here https://github.com/jilleb/mqb-pm/releases. Be sure to read the readme on https://github.com/jilleb/mqb-pm
Changelog:
v0.42B
Changelog previous versions:
v0.40B:
v0.39B
v0.38B:
If it doesn't work while it did work in a previous version, try an older version of aauto-vex-vag:
https://github.com/martoreto/aauto-vex-vag/releases
Hi all,
Download:
Changelog:
v0.42B
- New: Acceleration/brake indicator display optional
- New: Added Cupra Division theme
- New: Added Tesla theme
- New: Retro style theme
- New: Max-min value display is now split into 2 options: display values and display marks on the clock
- Fix: Fixed crash when no temperature data is available
- Fix: Wheel angle clock display
- Fix: Removed Fahrenheit and Celcius for the time being
- Fix: Improved G-force icons
- Fix: Textviews with G-force, degrees, percentage and Volts are now functional
- Fix: Improved Clubsport theme
- Fix: Gearbox temperature clock
- Fix: Various other small bugs and issues
- Fix: Code cleanup
- Fix: Moved strings to strings.xml, for easier translation (new languages will be in a future version)
v0.40B:
- Fix: Added all missing code for data elements on the 4 data views
- Fix: The 4 textviews should now be functional.
- Fix: Set RPM textview to have no decimals
- Fix: Fixed a bug with EcoHMI_Score
- Fix: Handling NoRecommendation on recommendedGear
v0.39B
- New: Added Skoda ONE theme
- New: Added Consumption data to clocks
- New: Added Recommended Gear to text elements
- New: Needles go invisible in high-visibility mode (you don't need them there)
- Fix: Acceleratorposition clock value
- Fix: correctly escape ' character
- Fix: Improved some icons
- Fix: Credits screen
- Fix: Added stopwatch background for Audi themes
- Fix: Improved Audi needle
v0.38B:
- Fix: Correctly escaped ' character in "G's"
