Bryans12v
- Hudson Valley, NY
- 19 GTI, 22 Tig Rline
No, shim kit is needed for all as new bearings should be installed.I thought the shim kit was only for DSG transmissions.
Thank you for all the info. You did a lot of mods to that thing. I bet it feels way different. I’ll order all the hardware and should be good to go. I work at a major semi truck dealership and can use a bay to do the work so I will have plenty of space and tools. Good call on the flange bolts. Would not have thought of that.Did my install over the holiday weekend. Figured it was time to do a few other items (alum subframe, rline dogbone, rs3 bushings, master cylinder brace, fsb, adjustable end links, turbo wrap, and tmd. Also had to swap in the stock downpipe to for yearly inspection.
The install was tough for one guy but doable. I took my time, went by the book and did it all over the course of 3 days. Spent about 3 months planning though so I guess it went pretty quick in retrospect.
View attachment 250981View attachment 250982View attachment 250983View attachment 250984View attachment 250985View attachment 250986
Anyone wanting to tackle this job, make sure you have all the correct tools and repair manual. All box codes aren't the same. You'll need a propane torch or heat gun, 75-80mm blind race puller, various sizes of race/seal installers, dial indicator, bench press, torque wrench just to name a few. Plan to replace almost every bolt you have to take out, especially the aluminum T45's that bolt the case halves together. Get new input/output shaft seals, oring for the selector shaft, shim kit. Do NOT torque the flange bolts into the diff at 33nm as the manual calls for. The diff isn't hardened like the thrust plates are on the stock diff. I'd go maybe 18nm max with blue loctite. Use NEW bolts here. Folks with PP, you'll need a 1/4" drive 6mm Allen with a long extension about 14" to get to the passenger side through the ediff.
Alright so... wavetrac is off the table.Anyone wanting to tackle this job, make sure you have all the correct tools and repair manual. All box codes aren't the same. You'll need a propane torch or heat gun, 75-80mm blind race puller, various sizes of race/seal installers, dial indicator, bench press, torque wrench just to name a few. Plan to replace almost every bolt you have to take out, especially the aluminum T45's that bolt the case halves together. Get new input/output shaft seals, oring for the selector shaft, shim kit. Do NOT torque the flange bolts into the diff at 33nm as the manual calls for. The diff isn't hardened like the thrust plates are on the stock diff. I'd go maybe 18nm max with blue loctite. Use NEW bolts here. Folks with PP, you'll need a 1/4" drive 6mm Allen with a long extension about 14" to get to the passenger side through the ediff.
Yes, I knew about the bearings which I already have and I talked to the folks up at FFE and they have shim kits at their shop so they will be installing that when they rebuild my transmission.No, shim kit is needed for all as new bearings should be installed.
