It's always something minor that causes the frustration.
Like we talked about earlier, if it were me personally, I wouldn't be stressing too bad about that c-clip not being in there. As long as your fittings are tight (which you said they were) then that zip tie should keep it from rattling on the bracket. I would put it on the to-do list of getting it corrected though, just because. I'm not sure how easy it is to replace the hard lines, but it shouldn't be terribly hard aside from snaking the new one in. I'll take a look at mine tomorrow.
You're rears might be in the same boat, so prepare for that.
@krs Thanks for the help last night! I appreciate you letting my vent my frustrations as well. Lol
I have everything put together and decided to let the car sit over night to see if I have any leaks as I'm a little worried about the movement in the hardline.
No visable leaks this morning so all I need to do now is bleed the brakes. Though I have to pick up my son at some point this morning and my wife is out of town...then there is this game tonight so I'm not sure I'll get that done today. Sorry...the suspense may have to build a little longer.
Aside from the issue with the upper portion of the brake line, the install when smooth. Rotors came off with no effort on both sides and this was a sign to me early that there was going to be an issue. Can't be this easy...Lol
Here are some pics of the unfinished project, the two pics of the brake lines are one of the passenger and driver sides. The driver one has some marks on it for when I tried to hold it with pliers (and blue paper towels to prevent them marks which did not work of course).
Also I could not find pics of anyone running this kit with Pretoria's. I did read on killerbrakes.com that you may need an 11mm spacer. I chose a 12.5mm spacer and you can see that it clears...
