Hello,
I recently purchased the MK7 to MK7.5 Facelift LED Tail Light Adapter Harness for MK7 and the corresponding OEM MK7.5 LED Tail Lights from shopdap.com. I completed the wiring, installation, and coding today, and everything seems to be working except for the Reverse Light on the Driver's Side (see attached photo).
Some additional info:
-- 2016 Golf R (US)
-- I was NOT planning to code for a rear fog light, so I inserted the green wire into pin 6 on the Driver's Inner Harness (see attached photo).
-- I used the OBDeleven app to perform the coding with one touch. My ODX version was 15001, so I chose "LED OLD BCM".
-- In the "Faults" section of the OBDeleven app, I'm getting Fault Code B133315: "Left brake lamp/turn signal bulb"
What should be the next steps in troubleshooting this issue? Has anyone seen a similar issue before?
Thanks!
-- 2016 Golf R (US)
Thanks!
