ryohei47
- SF Bay Area
I might have missed this, but has anyone explained why it isn't necessary to use VCDS for the DSG service when using the measure-fill method?
One thing I’m not clear on. Is the car supposed to be level and RUNNING when checking volume after the new fluid is added?
It's not necessary to use VCDS during the measure-refill method because as long as your transmission fluid and the gearbox itself are relatively the same temperature (say around ambient temperature) your volumes will be close to identical (since temperature differences=volumetric differences). It's still recommended you do a gearbox adaptation following service.
Factory drain and refill basically slightly overfills the gearbox at the correct temperatures (max volume needed at operating temperature) using the snorkel to overflow. This makes sure exact volume at the correct temperature is added with no chance of underfilling.
Most dealer techs simply fill the car with 5qts and send it on its way, is what I have learned from said techs.
If that’s the case is it doing any damage having the extra .3(ish) liters in the transmission?
This.
The VW procedure is a damn circle jerk. Car at room temp, drain, refill 4.6-4.7L, new filter, done.
No way I'm messing with their procedure. Its a very cumbersome way to do a very simple thing, fill a case with the proper amount of fluid.
I carefully measured what came out, got 4.51L. Most people settled in the 4.6-4.7L range, so I split the difference and added 4.65. think about it, if you're off by .1 that's 3oz of fluid in an entire transmission. Completely irrelevant.
It was exceptionally easy for me to do. I left the car on the floor of my flat garage as you can reach everything you need to without lifting the car. Removed airbox, battery tray, then opened the filter. It is best to do this after the car has sat overnight to let the filter drain so you don't get a big mess. Took the filter out then went under the car and opened up the drain bolt. Let it all drain, then remove the snorkel and wait some more. Once thats all done I used this fluid/filter kit and this funnel to do the change. The end nozzle of the funnel fits directly into the filter port so you can fill it from the top very easily. I put in the full bottles then installed the new filter/airbox/battery and let the car idle for about 5 minutes while switching through park/reverse/drive/neutral etc. Using OBDeleven I monitored the transmission fluid temp and when it hit 35c-45c I removed the main drain plug WITH THE CAR RUNNING and let the excess drain till it was a light trickle. Once thats done close everything up and use OBDeleven to do a transmission recalibration (I just used one of the apps for 10 credits). Thats all there is to it. Took about the same time as an oil change and was just as easy.
Edit: If you use that funnel, pull out the mesh filter in the base of the funnel. This will allow the fluid to go in much faster. It only took around 2 minutes per bottle.
Edit 2: Total cost for me at the end was around 120 bucks vs the 350 a private shop quoted vs 750 the dealer quoted. Very glad I did it myself.
I dont recall where Ive read it before, perhaps the tdi forums, but people were saying use the oem fluid over anything else. Basically stated that non oem fluid, has to be changed a lot sooner then 40K.
Anyways, nice write man.
-Also For the people that fill it from the top; what you take out is what you back in is what I heard? I dont follow how you find out the fluid level of dsg?
You measure what you take out and put that volume back in. That's why you should do it when the car is already cooled off so the fluid isn't hot/expanded.
You can also double check by heating the car up and letting any excess over the snorkel drain out. I did this just to double check that I out in correct amount and only had a slow trickle.
