A bucket of warm water, and just a tiny bit of laundry detergent. Don't saturate the seats. Wipe them with a wet cloth, then follow up with a dry cloth, if you have to do that several times it's still better than getting the seat too wet, and having the water seep into the foam. Once dry, spray the fabric down with scotch guard.What's everyone using to clean up the interior cloths? My center console and door arm rests could use some love, might as well clean the seats too.
Worm clamps definitely not....ask me how I know. There's a much better T-bolt style called constant tension which basically allows you to tighten it down further and when the heat eventually gets to the silicon hoses, the spring will clamp down on it as it shrinks. More expensive but definitely worth it if you don't want to deal with the hoses popping off. I've ruined a lot of track sessions with hoses that popped off causing me to jack the car up, tear it apart and re connect the hose. Eventually converted everything over to constant tension and haven't had an issue since.Is a worm gear style clamp enough for the outlet pipe on the turbo?
Or should I go with something like this?
The OEM pancake pipe has a regular worm gear so I was just going to go with that but a co-worker has me thinking I should order the other style which seems overkill.
First post ... first stupid question ...
Just bought a 2012 GTi manual a few days ago. I haven't had a turbo before, so it might just be my inexperience, but I've noticed something weird.
When I go say about 60 in 5th and put my foot down, the revs seem to increase slowly at first, but then jump up, but I don't feel like the speed increase matches the revs increase, if that makes sense. It kind of feels like it's electronically shifting back to 4th, but that doesn't make sense to me.
Is that just the way the turbo reacts?
I suppose clutch slip is a possibility. I don't feel it under normal acceleration, only when I put foot down in 4th or 5th.If it starts to act like it's free revving, clutch slip. Do you know if it's tuned or not and what's the mileage?
She's is at 103k. The carfax indicated that she was regularly serviced at a VW dealership, so it should be in good condition, but yeah, I guess the clutch is a wear and tear item. Completely stock.
Thank you for the insight. I am thinking of modding some over time, money little tight now. But if I'm in for a new clutch anyway, I might us well get an upgraded one.Yea, you'll be putting more load on it in those gears. Wear item and also would be a key upgrade if you planned on modding.
