Cuzoe
- Los Angeles
I ran 034s on stock suspension, then back to stock mounts, then SuperPros on stock suspension, all within a 45 day period... the difference (on imperfect roads) is obvious. It's not intolerable by any means but it's quite obvious. I would also note that I drive a Golf so stock suspension for me is pretty soft.
I work at an airport and there's only one way to get to our hangar, I drive that same patch of road all the time, I know it well enough to avoid some of its "features" even in the dark. Here in LA taking Laurel Canyon coming from Hollywood there's a transition after the second traffic light when you're coming down the back side of the hill, maybe a 3/4 inch step... you will see the people that drive it often braking before it and the people that don't drive it often braking right after because it is jarring, if you're not paying attention it will scare you... Even with slowing down because I know it's coming there still a different sound with the stock mounts versus either of the camber mounts.
