All in your opinion Dave. You forgot that part.
The figures, & PDFs on FLD etc, info on the weights, etc are all other engineers facts, not my opinions,
We are talking about 2 specific cars the std GTi and P/P GTi, not cars in general. You keep opening the discussion up wider and wider, taking it farther off course to justify your position.
Other people where quoting me & answering by mentioning "race cars" & various other brand cars...all I did was answer their original posts...so don't blame me...
I am not saying any of that is wrong in theory. But you are so far beyond the scope of the original question, all in a quest to get the last word and prove you are 100% defacto correct, situation and circumstance be damned. It's called deflecting.
Nope its called arguing a point from every direction, never been to a debating society then??...
I am saying that in this question where the two cars are the same except one has and LSD and bigger brakes the latter seems to be the faster, more stable car in spirited driving. Straight line, the same, but who cares about straight line. You don't buy a GTi for straight line performance.
Agreed, but there is a 81kg weight variance between the specs of GTI 3dr manual & GTI PP 5dr DSG & I doubt the heavier car with the FDL & 340mm brakes will be that much faster for the money spent on it...
You're a numbers guy 100%, how did the P/P beat the std Gti around the 'Ring if it's an overweight pig?
I haven't found the those times everyone keeps stating, as the listings for ring state the car type eg GTI & GTI PP but not the door number or gearbox type, or even if the tyres & driver were the same...
Certainly you can take a stock 3 door GTi, strip it, put light weight calipers/rotors, better pads, Wavtrac, better rubber, lighter rims and it would outperform the GTi P/P.
No need to strip it out which is why I did not mention it, reduce the rotating wheel/brake mass/weight, instant faster acceleration...wavetrak & tyres for better traction etc etc..
But that's not even remotely the question and I don't think anyone here would dispute that, even if the cars in this example never ran against one another. Would it be as good a DD, maybe, but probably not. On the track, I'd bet the Stig could get better lap times with the quasi lightened 3-door GTi outfitted as above vs. the stock P/P. It wouldn't be jaw dropping but I'd expect a couple seconds maybe 3.
It'd be more than that, seen the ring time for CCS?.
Compare that to the same door & gearbox as a GTI PP...as the CCS is a GTI PP, but with 2kg lighter front discs (same size), reduced body weight, the same FDL, & slight suspension geometry tweeks...& a big spoiler...
