I had an Autocross event today at Thunderhill in NorCal. I run in STH but am definitely not optimized for the class (although my Aerofabb bits technically push me to DSP, I only go like 2-3 times a year so I'm not competing for anything). This was only my 3rd autocross event so I'm still learning quite a bit. I also had brand new Yokohama Advan Apex V601s (280 treadwear, basically A052's little brother) and a new brake kit, so that combo took a little getting used to.
My runs were as follows:
For reference, no one in AS/BS/CS time went under 45.0, most people were in the 46/47 range. Best time of the day was 43.3 from an incredible driver in an absolutely dialed in STU E92 M3. Dude was seriously kicking ass.
Run 1: Trying to be smooth and learn the course, felt decent
Run 2: Accidentally left traction control on and was fighting it the whole time
Run 3: Overdrove two sections on the first half and lost a lot of time but had a good second half of the lap
Run 4: Pretty solid lap, but definitely still left at least a second out there. I think I could do around 47.5, maybe 47.2 if I really nailed it. Wish I could've had a fifth run but it was incredibly busy today.
Here is an in car view of my final run (make sure to watch in 1080p or 1440!)
Also some bonus rooftop (Gran Turismo view) footage from my second run.
I am open to advice/constructive criticism. Personally I noticed a few things. 1) I short shifted into 3rd a few times. Should've probably just run out 2nd. 2) I broke quite early and easy into a few turns, I think with more time with the new brake setup I will get used to its limits. 3) I need to be a little smoother and more patient in some of my transitions, letting the car settle so I can put the power down more efficiently.
Overall had a blast though! Car ran flawlessly and nothing broke so that's always a plus.
@catacon, whose springs are you using?
do you have any photos showing how the tires fit from the front or rear? maybe some close ups showing clearance?Figured I'd throw my STH setup into the mix. I ran GS the past two years - won the PAX championship in the STL region last year and trophied at Spring Nats. The smart thing to do would have been to stay in GS, but I wanted to have a little more fun with the car.
Current setup is:
Wheels: APR A01 18x9 +40
Tires: 265/35R18 RE71R
Shocks: Koni Yellow fronts, TC Kline DA rears
Springs: 430# front, 550# rear
Camber plates: Ground Control
Coilovers: Ground Control conversion kit - ~0.5" drop
Swaybars: Stock front, 034 rear - full stiff
Camber: -2.0° front, -1.8° rear
Toe: 0.0° front, 0.14° in rear
Exhaust: muffler delete
Tune: Stage 1
Ran my first event with the setup on Sunday and the car felt great. Turn in is really good and the car felt very stable. Transitions felt good and body roll seems well controlled. Had some cone trouble so ended up 5th in PAX, but had a good enough scratch time for 3rd. I have another event this Sunday, so I will do some more testing on this setup.
I know there's been a lot of questions about the 265 setup with 18x9s. +40 offset seems to be about perfect - slight poke, but not bad. I had minor rubbing on the front fender screws which the screw mod will fix (should have just done this from the start). Right rear is rubbing the fender liner next to the filler neck, but no signs of rubbing on the neck itself. I did shift the gas tank over, but I'm not sure I needed to. The course last Sunday was a good test for rubbing as there were a few sections where the car was loaded up, near full lock, and then a significant bump on course. If it didn't destroy anything then, I think it'll be good. I did have some rubbing on the front fender liner right after install, but that was pre-alignment with 1.4° total front toe - no issues with a proper alignment.
I'll be ordering a downpipe and intercooler this week and hopefully have them installed for an event later this month. I also need to figure out a solution for front camber. The Koni Yellow adjusters stick through the shock tower and limit front camber to -2.0°. I asked GC about this specifically and they said it wouldn't be an issue, but it is and the only fix is to modify the shock towers which isn't ST legal. Overall, though, I'm really happy with the car and my first crack at a setup. I think will a little tweaking of alignment and damping, the car will be pretty well set.
Glad to see someone running the GC coilover conversion. How are you finding the spring rates? Have you played around with the height adjustment - curious how low you can get it.Front:
I was following Cliff's thread where he ran a Ground Control's prototype a few years back, I'm surprised they set you up with 7" front springs instead of 5.5" springs - and now also 8" rears instead of 7".
I'm still trying to sell a kit I was told fit a MK7 but is in fact for the MK5, 5.5" 475# fronts and 7" 600# rears Was really looking forward to running them.
for aesthetics, maybe just an inch and a half lower it'd be perfect.
