Hi,
Not sure whether this has been seen by anyone else but it would appear that the underseal on the jacking points under the car has split, and the metal can be seen through the broken underseal!! There doesn't seem to be any rust showing and the metal appears to be clean - I can only assume that this has come off when it has been at VW for a service or if the previous owner has ever had to jack the car up, as I have never used the scissor jack or any other jack for that matter to have the car off the ground :/! Is this something I should be concerned about?? I assume that all this metal will be galvanised, but do you think it would be better just to slap some waxoyl onto the exposed metal and keep a check on it every time I wash the car? I assume that, despite being under warranty, VW wouldn't give a monkeys about this!
