Sachs Racing Clutch vs Southbend Stage 3 Daily
Ghawkins
Ohio
Thats an interesting set up he compiled. Its simply a sachs disc. Ttrs pressure plate as the 2 main components. I wonder how much the ttrs plate is rated for? Been trying to google that to no avail
Sachs rates this clutch at 405 ft. lbs torque.
Jlungo
New Jersey
smoriarty
Texas
Isnt the sre stage 1 set to 405+?
Sent from my SM-G920P using Tapatalk
no, stage 1 is usually around 320-380ft lbs depending on tune.
Jlungo
New Jersey
Not talking about the tune. Talking about what the SRE stage 1 clutch is rated to handle
Jlungo
New Jersey
Up to is38 tune
That concerns me because I am runnimg the is38 on my gti and wanted something that went well past what im touching to give me some security
2015WhiteGTI
My understanding for the 405 torque rating is at a constant run and rated at that for the long term. I've heard that the actual clamping force can handle over 450 ft lbs.
I won't be launching my car, so I won't have to worry about that nor am I going over Stage 1.
My car is getting a ton of work done right now. We're having an issue with the brand new replacement transmission so it's holding things up at the moment. They had to pull out the new transmission and pull it apart again to see if there is an issue. They found something and are in the process of fixing it. I'm doing a Peloquin LSD right away too.
Jlungo
New Jersey
Yes it was you doing the pelo diff. I was trying to remember. Is it your stock trans that is the issue right now?
St. Olaf
Jlungo
New Jersey
Well the 550nm+ is the same as 405ftlbs+.
Jlungo
New Jersey
Think i have elminated southbend and the whole smfw notion based on the fact that i dont want more chatter and wear on the transmission. The dampening on the dmfw will make a daily more comfortable and still get the performance needed with the higher rated kits
Universal_Remonster
Wise decision. The SRE and the DIY TTRS seem to be the way to go.
BravoMike
Indianapolis
