mk7matteo
- Santa Clarita, SoCal
shoooot I am just now seeing all the negativity about this intake shortly after getting one. At least I got it second hand for super cheap. Probably gonna sell it off again soon..
I really cannot understand why someone would buy an open intake when it clearly reduces performance. Cosmetics and noise? Wow.
Lol I don't want it, I just want to test with it to see how bad the IATs are
I've tested the IATs here on mine, honestly there is not a difference under normal driving. When fully warmed up in 80 degree weather, stop and go traffic, both the stock intake with stock filter and Injen SP run 40 to 50 degrees above ambient for me . I did measure under hard acceleration the stock intake runs about 5 degrees cooler than the Injen SP, which is what matters most I guess. Tooling around there is no difference in IATs.
I swapped back to the stock intake mostly because I want to make sure the air is filtered well, I don't trust the Injen cone filter and hoses.
Good to know! When I tested an open filter on the stock plastic pipe, moving was about a 5-10degree difference. Stopped, the stock air box was cooler, but heated up to about the same after a couple minutes. Does sound like the metal pipe increased it quite a bit more when sitting
This particular thread is just about the injen SP intake only, which appears to have a design flaw which causes it (in 20+ owner cases) to mix engine bay air with external air, resulting in elevated BAT's. It either doesn't seal completely with the existing cold air inlet source, or doesn't seal at all with the heat deflector.
This is exaggerated if the areas environment is humid and high heat, which exaggerates the issue. In the cooler months, the car isn't as negatively effected, as its still getting relatively decent inlet temps. (so lots of people love the intake in the winter, or in cool temperate areas).
I know gn4whals solved his main issue with the intake by opening up a duct so it would actually receive some external air. That combined with some extra sealing material around the deflector, could help with the issues.
I have not seen any complaints (nothing like this) with other open element intakes, such as the neuspeed, cts, rock, etc. It mainly seems to be the SP as a lone issue causer.
For those that have no issue with their injen, do you mind snapping some photos of it in the bay? I wonder if they changed the sealing material (or increased its size). There could be more then one revision of it.
