worldacgti
wow....weird........
My XDS is set to strong.I'm gonna try a few different things to see if I can get it to work. I will report back. Question to the guys that have got it to deactivate....is you XDS set to strong? Mine is completely deactivated
Escape Hatch, did it also give you the option to deactivate torque limiter as well?
For those of us that can't completely disable, I can say that with the setting on normal, the nannies really don't kick in.....
This is a nanny that you won't notice getting in the way under most conditions. EDL/XDS is "silent" unless it is interfering so bad you get wheel hop. Most people have no clue when this is actually doing its job.
I set my car from normal to strong and could tell a positive difference in driving, but I don't launch the car and don't have problems with wheel hop.
There is no real issue with disabling personally I would limit it to the drag strip and leave it on the rest of the time as it will likely help more on then hurt in my opinion.
This has also been a known thing since at least 2014 http://forums.ross-tech.com/showthread.php?796-MkVII-Golf-XDS-Adaptation/
It's been posted here several times, shocked people were not paying attention as I thought this was sort of just a known thing and have mentioned it myself here as well in a few threads.
Um, this thread has nothing to do with XDS. Do try to keep up.
I believe he was commenting on it because some people had it disabled and he was just starting that you should keep it on for most driving basically. I think that was the point and not trying to deter from the OP
Personally it is archaic technology if you are using ABS to counteract wheelspin. The ECU should modulate throttle not slap the throttle shut. Really annoying when you constantly have to go easy on the throttle even with ESC off.
