Remove Torque limiter Via Vag-Com (How To)
JerseyDrew77
Virginia & NC
2016 TR GTI S 6MT
Hi all
I did this mod using OBDEleven.
Set Torque limiter and Starting Vibration to OFF and noticed wheel hop.
Am I being silly, or do I need to also have ECS also off? ( i have also done the mod for this to completely disable)
Thanks
You'll continue to get wheel hop until you upgrade your mounts and suspension.
CarolinaGTIMk7
jacksonville NC
2016 GTI SE
Credit to GIAC for figuring this out with the help of Rich at dub werks:
Enter ABS controller, select adaptions, select "starting vibration reduction" from the drop-down menu, change the value from Strong to Deactivated.
Congratulations, enjoy full power with 0 intervention in 1st, 2nd and 3rd. It totally transforms the car. Now if only someone can figure out how to code out the launch control lag.
I can't find the 'ABS controller' section in my obdeleven. Can I get more directions. Went to brakes app, then nearly everything in there to no avail. Badly want to turn off my ECS.
