Faceman
- Long Island
- '17 GSW 4Mo
Sounds like the wrong lubricant was used.H&R in the Mk6 were silent.
Superpros in the Mk7 creak like a pirate ship.
Sent from my SM-G975U using Tapatalk
Good choice. Add the alignment I recommend and some good tires. It'll be a world class handler.I just ordered a 26mm H&R I’ll review it once it’s on
You mean the Super Pro supplied lubricant?Sounds like the wrong lubricant was used.
Next time try this: https://www.amazon.com/Energy-Suspension-9-11104-Formula-Prelube/dp/B000CN7B4IYou mean the Super Pro supplied lubricant?
Sent from my moto x4 using Tapatalk
Sent from my SM-G970U using Tapatalk
Was it a white almost clear super tacky/sticky lube? If yes then that's correct poly bushing lube. Whiteline sent me some weird almost CV axle grease that I didn't use for some other poly bushings I used before. If I recall my super pro control arm bushings came with true poly lube.You mean the Super Pro supplied lubricant?
That is a solid top 3 but I'm now finding a lot of sway bar options to be too stiff after doing a full suspension upgrade including 034 bars. Even soft might be a little too stiff so I definitely recommend an adjustable bar if you're planning to add coilovers or a front bar.The 3 best mods you can make to a GTI are a big ass rear bar, good tires, and stg 1 tune.
It's the car VW should have sold us.
I believe you. The product I linked you to works wonders though.Superpro supplied lubricant was used and everything was assembled to specification with new fasteners. Shit's just creaky.
I would double check the sway bar brackets and endlinks first. A lubricated bushing won't be the cause of noise, something else is going onSuperpro supplied lubricant was used and everything was assembled to specification with new fasteners. Shit's just creaky.
