Rare Ara S3
- Michigan
- 2017 Audi S3, GTI
I already thought about the controller. I have the silver one still. Also I wondered if the lines would lower DCThis is still EQT right? Do they run closed loop?
I assume they'll probably steer you towards upgraded fuel lines. Do you have the updated RS3 LPFP controller already?
Get the black one (revision recommended), DC will be lower.I already thought about the controller. I have the silver one still. Also I wondered if the lines would lower DC
Someone's autocorrect is naughtyRemoved the two bolts securing the rail gave me the cunt hair I needed to pull back on the rail and thread the fitting in.
Sounds high. Did you ever switch to the other controller? I think I’m at 70% at 34 psi.Been awhile without an update. Purchased an E85 map. First logs on the base file indicate my RS3 LPFP is 75% DC at only 25psi of boost. Seems concerning.
Any suggestions?
lol learned something new today. Going to have to sneak that in casually at work now. At first I thought you were fucking with me, but Google said otherwise.That's an appropriate saying in that situation, I don't think it was autocorrect
Lol that was 100% what I meant to type.That's an appropriate saying in that situation, I don't think it was autocorrect
I didn’t. I’m waiting on a harness. For whatever reason I thought it would be the same connector as the factory one. Should be here any day. That’s Interesting that yours is 9psi over my base map and 5% less DC. I assume you’re on the black controller?Sounds high. Did you ever switch to the other controller? I think I’m at 70% at 34 psi.
You can sort of tell what I was referring to here in this pic. That collar was hitting the head before I could thread it inlol learned something new today. Going to have to sneak that in casually at work now. At first I thought you were fucking with me, but Google said otherwise.
Guess I was wrong. This is my most recent log. What E percentage are you seeing? My local fuel is E75-77. I'm also standard housing but I doubt that makes much difference.I didn’t. I’m waiting on a harness. For whatever reason I thought it would be the same connector as the factory one. Should be here any day. That’s Interesting that yours is 9psi over my base map and 5% less DC. I assume you’re on the black controller?
I don’t know what else it could be.
Oh dang only 60% DC. My gauge is reading 80% E. It was around 75 when I did the last log thoughGuess I was wrong. This is my most recent log. What E percentage are you seeing? My local fuel is E75-77. I'm also standard housing but I doubt that makes much difference.
https://datazap.me/u/wastegate13/log-1661541283?log=0&data=8-15-30
