Hey, i got it working, The fix was to just enter the code string all the once instead of doing it 1 by 1.
but now there is a new problem. when i put the car in reverse the light near the gear shift selector starts blinking which means something is not working properly. and when changing OPS Display from Ops to 360 ops the additional 4 sensors are not showing. instead the car thinks the rear and front regular sensors are the pla sensors(i attached images and they were taken when the car was in the same place. i did not move an inch.
https://ibb.co/jR2OPo
https://ibb.co/cKLXH8
And i know that the side pla sensors are working correctly, so its a software issue and im pretty sure it is not a wiring issue (i attached another pic)
https://ibb.co/egY5LT
And here is a scan of the car
OBDeleven data log
Date: 2018-06-27 15:12
VIN: WVWZZZAUZEW202106
Car: Volkswagen Golf
Year: 2014
Body type: 5-dr hatchback
Engine: CJZA 77 kW (105 HP) 1.2 l
Mileage: 124848 KM
01 Engine
System description: 1.2l R4 TSI
Software number: 04E906016A
Software version: 6393
Hardware number: 04E907309A
Hardware version: H08
ODX name: EV_ECM12TFS01104E906016A
ODX version: 001007
Long coding: 01250032232415082000
Trouble codes:
No trouble codes found
02 Transmission
System description: GSG DQ200-MQB
Software number: 0CW300047D
Software version: 5261
Hardware number: 0AM927769K
Hardware version: H43
Serial number: CU501310217832�
ODX name: EV_TCMDQ200021
ODX version: 001001
Long coding: 0014
Trouble codes:
03 Brakes
System description: ESC
Software number: 5Q0907379AA
Software version: 0457
Hardware number: 5Q0907379G
Hardware version: H31
Serial number: 63043000001328
ODX name: EV_Brake1UDSContiMK100IPB
ODX version: 033001
Long coding: 01FA6AA12420116E0378060041C92580562488C06082A4F300220038C202
Trouble codes:
08 Air Conditioning
System description: Climatronic
Software number: 5G0907044T
Software version: 0805
Hardware number: 5G0907044T
Hardware version: H02
ODX name: EV_ACClimaBHBVW37X
ODX version: 003018
Long coding: 00020004200100001005004012101800
Trouble codes:
09 Central Electrics
System description: BCM MQBAB B
Software number: 5Q0937084AB
Software version: 0124
Hardware number: 5Q0937084AB
Hardware version: H16
Serial number: 00011331000163
ODX name: EV_BCMCONTI
ODX version: 012001
Long coding: 00001C42C24102F34BE44000000403081000000000000000000000000000
Subsystems:
System description: WWS 131108
Software version: 0551
Hardware version: 042
Serial number: 131111085101
Long coding: 0E4DDD
System description: G397_RLFS
Software version: 0004
Hardware version: H06
Serial number: 90302826
Long coding: 06006C
Trouble codes:
U112100 - Databus missing message
static
15 Airbag
System description: AirbagVW20
Software number: 5Q0959655D
Software version: 0385
Hardware number: 5Q0959655D
Hardware version: 014
Serial number: 003F6R0273J$
ODX name: EV_AirbaVW20SMEVW37X
ODX version: 002130
Long coding: 98CCC000000000005C0000CF004800000065
Subsystems:
System description: SideSensor_Df
Software version: 0887
Hardware version: 001
Serial number: 3576700000074B181E0V
Long coding: 2D2D2D
System description: SideSensor_Pf
Serial number: 358670000005B3791E0-
Long coding: 2D2D2D
System description: SideSensor_Dr
Software version: 6149
Serial number: 3516502C5105064263BY
Long coding: 2D2D2D
System description: SideSensor_Pr
Serial number: 3526502991118A3142A$
Long coding: 2D2D2D
System description: FrontSensor_D
Serial number: 3556502A71118A33537%
Long coding: 2D2D2D
Trouble codes:
16 Steering Column Electronics
System description: Lenks.Modul
Software number: 5Q0953521P
Software version: 0135
Hardware number: 5Q0953569A
Hardware version: 075
Serial number: 20131106400111
ODX name: EV_SMLSVALEOMQB
ODX version: 001015
Long coding: 0410
Trouble codes:
17 Dash Board
System description: KOMBI
Software number: 5G0920861
Software version: 3390
Hardware number: 5G0920861
Hardware version: 204
ODX name: EV_DashBoardJCIMQBAB
ODX version: 008011
Long coding: 03A51A082390000800082A00040000
Trouble codes:
19 Gateway
System description: GW MQB Mid
Software number: 5Q0907530P
Software version: 1164
Hardware number: 5Q0907530E
Hardware version: 124
Serial number: 0001236641
ODX name: EV_GatewLear
ODX version: 010015
Long coding: 030100042B085700EF0002481C0F00010001000000000000000000000000
Subsystems:
System description: J367-BDMHella
Software version: 8043
Hardware version: H03
Serial number: 4503171803
System description: E221__MFL-DC1
Software version: 0038
Hardware version: H15
Serial number: 27130001882880073451
Long coding: 28FFFF
Trouble codes:
42 Door Electronics Driver Side
System description: TSG FS
Software number: 5Q0959593D
Software version: 0028
Hardware number: 5Q0959593B
Hardware version: 020
Serial number: 260115BAP18258
ODX name: EV_DCUDriveSideEWMAXKLO
ODX version: 006003
Long coding: 00310320D000040000001000
Subsystems:
System description: Fond FHSG DRV
Software version: 0002
Hardware version: 007
Serial number: 00000000000003325428
Long coding: 010000
Trouble codes:
B148754 - Motor for window regulator No basic setting
static
44 Steering Assistance
System description: EPS_MQB_ZFLS
Software number: 5Q0909144P
Software version: 1043
Hardware number: 5Q0909144P
Hardware version: 123
ODX name: EV_SteerAssisMQB
ODX version: 010031
Long coding: 0303
Trouble codes:
52 Door Electronics Passenger Side
System description: TSG BFS
Software number: 5Q0959592D
Hardware number: 5Q0959592B
Serial number: 010215BAU19038
ODX name: EV_DCUPasseSideEWMAXKLO
ODX version: 006003
Long coding: 00310120DC00040000001000
Subsystems:
System description: Fond FHSG PSG
Serial number: 00000000000003307788
Long coding: 090000
Trouble codes:
static
5F Information Control Unit
System description: MU-S--ER
Software number: 5G0035819A
Software version: 0421
Hardware number: 5G0035819A
Hardware version: 040
Serial number: V1C01211131479
ODX name: EV_MUStd4CPASE
ODX version: 002039
Long coding: 02730000FF00000011110001000900001F0103840100010001
Subsystems:
System description: ABT_Std_Radio
Software version: 0022
Hardware version: H51
Serial number: VWZ8Z9NJ7030KB
Trouble codes:
76 Parking Assistance
System description: PARKHILFE PLA
Software number: 5Q0919298K
Software version: 0054
Hardware number: 5Q0919298
Hardware version: H12
Serial number: 39461724100047
ODX name: EV_EPHVA2CAU3700000
ODX version: 003021
Long coding: 0031065011
Trouble codes:
U110F00 - (Sub) function cannot be performed
static
static
