combined?
I ran some virtual dyno numbers.. He's gonna whoop me hard with his 280 hp to my 280 hp.
combined?
An update for anyone who wants to do something similar - don’t. Haha. It actually makes the rev hang a bit worse. And the car becomes much harder to get started from a stop.Dang - thank you for replying though. Hopefully it's lurking in there somewhere. Otherwise it's trade-in time . Jk.
I definitely know what you mean with the clutch switches. What I'm trying to do is delay the turning off of the upper switch signal until my foot is at the floor, basically. I noticed that when coasting in neutral, if I rev the engine with the clutch not pressed, there is a lot less rev hang. Then, when I press the clutch in like I'm shifting normally, the rev hang is there. I'm thinking there could be a time interval right after you let off the gas where the ECU is looking to see if the clutch is pressed or not and that determines the rev hang behavior. So if I can delay when the ECU thinks the clutch has been pressed, maybe that would fool it into dropping the revs faster.
First I tried tying the upper clutch switch wire to positive (+) with a pull-up resistor, which made the EPC come on. Now I'm trying basically a NOT gate so the upper switch is always the inverse of the lower switch. Still throwing an EPC though :-/. I wonder if it checks the resistance of the switch as well.
I have a feeling it won't work. But it's a fun experiment at least.
To clarify what this means.Yes, I am still using hp tuners for actual tuning/calibration stuff...so I am using a bit of a hybrid solution currently for myself.
For those interested lurkers like myself, you need a hardware interface to get started. Correct me if I'm wrong on these sources
Hardware
Tactrix Openport 2
RaspberryPi Hat PiCAN3
Macchina P1
HPtuners
Probably not recommended...but one guy is successfully using the tools with a $35 alibaba openport knockoff too.
This is awesome. I noticed in the screenshot you have 5G0906259L_0002 as one of your files? Have you or someone been able to unlock and flash this ECU? This is the same one I have in my GTI (CXCB engine) so that would be great news.Yeah, I think most people would prefer the OpenPort option, at least how things are currently. If you're a linux guy you might enjoy one of the other options, but I think most will be more comfortable just doing things on their existing windows laptop.
Joe made a GUI for the flasher / OpenPort / windows and you can make that and his logger a single click icon on the desktop etc to make things easy.
maybe a random question, but for for us GTI owners with a piggyback tune, could this be an option that allows us to remove the limiter without going a full ecu tune?
edit 4 grammarz
