Dang - thank you for replying though. Hopefully it's lurking in there somewhere. Otherwise it's trade-in time ?. Jk.
I definitely know what you mean with the clutch switches. What I'm trying to do is delay the turning off of the upper switch signal until my foot is at the floor, basically. I noticed that when coasting in neutral, if I rev the engine with the clutch not pressed, there is a lot less rev hang. Then, when I press the clutch in like I'm shifting normally, the rev hang is there. I'm thinking there could be a time interval right after you let off the gas where the ECU is looking to see if the clutch is pressed or not and that determines the rev hang behavior. So if I can delay when the ECU thinks the clutch has been pressed, maybe that would fool it into dropping the revs faster.
First I tried tying the upper clutch switch wire to positive (+) with a pull-up resistor, which made the EPC come on. Now I'm trying basically a NOT gate so the upper switch is always the inverse of the lower switch. Still throwing an EPC though :-/. I wonder if it checks the resistance of the switch as well.
I have a feeling it won't work. But it's a fun experiment at least.
I think a lot of cars have rev hang now for emissions reasons. The Subaru Crosstrek I drove before I got my Alltrack was WAAAY worse. It felt like I had to wait like 3 seconds before I could put the car in the next gear. Rev hang saved me from buying a less fun car. Thank you rev hang.
