Odd 7.5 euro tail behavior
xvxmk6
denver-ish
2018 GTI
Emailed Ed about this issue, but covering my bases in case anyone has a quick fix for me.
Recently installed OEM 7.5 tails from Ed at BEC autoparts, used his harness and coded via his instructions. Noticed this strange behavior in the reflection of a building I was parking in front of the other day.
Lights function normally, brake lights and running lights all work, but when releasing my foot from the brake, the entire bottom section of LEDs lights up to the brake light brightness. Not the end of the world.. just jarring. Attaching photos below.
Running lights
Brake Lights
Immediately after releasing brake pedal
ZERO815
Köln Germany
2017 GTI SE DSG
Never seen that before. On both sides? Please share the whole coding of Leuchte20.
xvxmk6
denver-ish
2018 GTI
Sorry for the late reply (I was actually just writing you a PM!) My car has been in the shop for some body work, will post Leuchte20 coding when I receive the car back this afternoon. Thank you!
xvxmk6
denver-ish
2018 GTI
Hi zero,
attaching screenshots of Leuchte20, cant figure out how to export a channel in a txt document via obd11..
edit: and yes, it’s on both sides. Thank you!
ZERO815
Köln Germany
2017 GTI SE DSG
Thanks for the pics. The coding for Leuchte20 looks okay to me. That's indeed odd. To my knowledge the parking light on the outer tails have three rows. The top row iluminates with the parking lights on, and stays on w/ parking lights on and brake lights on. Second and third row change their pattern and brightness from two rows to 6 double dots depending on parking light or brake light. Changing the value of "Leuchte23SL HLC10-Dimmwert AB 23" (Parking light left) doesn't change the brightness.
Do you have the European VW OEM tails or are these the Chinese VW OEM parts? At this point I don't suspect this to be the route cause. You said the behaviour is the same on both sides, that makes me believe it's not a random faulty light.
I have seen flickering brake lights w/ parking lights on if "Leuchte20BR LA71-Dimmwert AB 20 = 100" and "Leuchte23SL HLC10-Dimmwert AB 23 = 127". What's the current value of "Leuchte23SL HLC10-Dimmwert AB 23" in your car? Is it < 127 ? If possible please share the Leuchte23 settings as pics (like Leuchte20).
xvxmk6
denver-ish
2018 GTI
They’re the OEM Chinese market. Yeah it’s very strange that i can’t find a reproduction of this behavior anywhere online. Ed doesn’t know what’s going on either.
Heres those screenshots. Thanks again for your help.
ZERO815
Köln Germany
2017 GTI SE DSG
Doesn’t look like a coding issue to me. How is it wired? Pics?
xvxmk6
denver-ish
2018 GTI
Here are photos of the harness and connectors. Let me know if you need anything else. This is the left side.
to body harness
Rear
to tail light
Tail light connector
ZERO815
Köln Germany
2017 GTI SE DSG
Appreciate it. Wiring and coding for brake light and parking light are as expected for European tails, nothing suspicious. Don’t know if the Chinese market lights are different in any way. Do you somebody around you w/ the European lights for a simple tail light swap? Just check if the odd thing moves with the lights?
xvxmk6
denver-ish
2018 GTI
got a friend a couple hours away with euro market tails. I'll ask him and see what we can work out. I'll report back.
Thanks!
xvxmk6
denver-ish
2018 GTI
Got up with my friend, we swapped tails and the behavior follows the tail lights. I'll be contacting Ed, thank you for your help, Zero!
fghtffyrdmns
Earth
Because I'm curious, is this with the updated harnesses? My harnesses should be arriving today (also Ed's, and also a 7.5) and I'm trying to cover all my bases ahead of time so that installation goes as smoothly as possible.
I got my Euro 7.5 lights from him for my 7.5 R with his harness. What I did was connect everything up and do the coding to test everything before I started pulling apart the trunk to run the cables in their permanent spots. Everything worked as should on my set.
