I have tried for far to long (almost a week) to gather information and have always been a forum lurker. I was going to write out this huge post about my sob-story and decided to go bullet points and get to the actual question.
-Wife in hospital with brain surgery back in aug of 2018
- I after 2 months of hospital stays and my wife Being moved to rehab, screw it im going stage one as a stress relief. Let hope my clutch last for some time
- the day my wife is about to start to relearn how to walk my bother finds my mom has past away and is freaking out.
- I leave to go help knowing that there is no time to flash back to a 91 tune
- 2000 miles later it’s running very rough and my clutch is slipping.
- new spark plugs, stage 3 bfi clutch, and wavtrac lsd to save on labor because I knew I would do it eventually.
-get home and it’s leaking, shop takes it back and finds they didn’t align it right and clutch is really bad but “that’s normal” ok I will adjust
- get it back and it’s leaking
-shop replaces every transmission seal
- leaks again
- shop fixes, puts new brake pads and calipers, puts a apr down pipe and flashes to stage 2 for free because of the inconvenience and drives 100 hard miles to make sure there are no problems
- on the drive home I loose the clutch as the bleeder valve explodes on the freeway.
- changed the bleeder valve to a aluminum one but they were suspicious of the clutch being wierd and ecs sent a southbend to replace it with.
- then after only a week of having it the car just dies or shakes at idle.
- i am doing everything right this time. I will not even look at the gas pedal till 500 city miles and not look at redline till 1000. 500 came and I had not even been able to feel the new mpss4s tires I put on because my other ones were not safe anymore.
- so I gave it a little gusto to 4500 rpm in a corner and my clutch pedal started vibrating like crazy the second I touched it.
- I parked and was told that it probably was friction matirial the was on the flywheel unevenly. “I hate to tell you this but drive it a little harder and see if it corretcs itself”. If it’s a bad clutch it will have to be replaced anyway.
- I am on the freeway and dropping it into 4th and give it some gas and......wow where is all the power? Is the clutch slipping or bogging the engine down? Lights stared going off and it went into limp mode. Pulled of the highway where it died
- metal was found all in the oil pan and bearings in the oil filter.
-you need a new engine.
- wtf I just want my fricken car to work!
- this saga has stretched from sep 2018- mar 2019. And have driven my car a total of a couple weeks in that time
This is my question/ask
Where can I get a good motor with less then 20k miles. Should it be stock, should it be built. Did you just total your car and you are waiting to sell me a perfect engine? I don’t want to believe this car or the shop sucks, they have been really great through all of it but I’m starting to loose hope. I get it, pay to play but I f I was aware of what a $700 tune was going to snowball into, I would have stoped while I was ahead and choose to deal with stress by getting a massage or somthing. Any information I can gleen from you all would be much appreciated and sorry...you got the long version anyway.
- leaks again
