BecauseMotor
- Brooklyn
New Thread Post... My TPC20 Turbo Build... (06/09/2020)
I'm a 2015 GTI w/ Performance Package and DSG. I'm currently Stage 1+ Unitronic with the following engine upgrades:
- Unitronic Air Duct, Air Intake, Intercooler, Charge Pipes, SAI Filter
- CTS Turbo Inlet Pipe
- Fluidampr Crank Pulley
- BFI Stage 1 Engine and Trans Mounts + Dogbone Insert
- Unitronic Stage 1+ ECU + TCU Tunes
Here's my build thread for my TPC20. Just ordered everything. Should have everything by the end of the month and installed shortly after that. I'm planning on getting everything dynotuned so should have numbers once complete.
Parts Ordered:
Original Thread Post... Going TPC20. Fueling Options? (06/07/2020)
As the title says, going to swap my stock IS20 for the TPC20 Stage 3 turbo. They claim ~420whp/420wtq with stock fueling on 94 pump gas. My plan was to stay stock fueling but tuner recommends going with LPFP and MAYBE MPI... but I've heard that others are simply running upgraded HPFP and calling it a day. Also just saw upgraded fuel lines from LPFP to HPFP are supposed to help a good amount as well.
Curious on thoughts if I need anything fuel system wise, and if I do, which way to go.
Parts Ordered:
- TPC20 Stage 3 Turbo
- OEM Diverter Valve
- VW OEM Turbo Install Kit
- MAPerformance Catted & Resonated Down Pipe
- Vibrant 17930 Resonator
- Wortex Aluminum Oil Pan
- LiqiMoly Oil Change Kit + Extra Quart for larger oil pan
- NGK R7437-8 Spark Plugs (if needed)
- RS7 Coil Packs (if needed)
- Looking at UM for tuning
