Cuzoe
- Los Angeles
It's been a month... I know you're busy playing around with memory seats and fancy child locks , but we need updates, haha.
Wednesday,21,August,2024,13:43:29:11868
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
VCDS Version 24.7.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240715 DS356.3
www.Ross-Tech.com
VIN: WVWZZZ3CZJEiichel License Plate:
Mileage: 194370km-120775mi Repair Order:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 18 19 2B 36 3C 42 44
47 4B 52 5F 65 69 6C 6D A5 BB BC CA D6 D7 8126 8127
VIN: WVWZZZ3CZJEiichel Mileage: 194370km-120775miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
4B-Multifunc. Module -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
8126-Trq distrib RearL axle -- Status: Malfunction 0010
8127-Trq distrib RearR axle -- Status: Malfunction 0010
Address 01: Engine (J623-CJXB) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 F HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13--- CVN: B7DB7878
Coding: 091D003A2476050B3004
Shop #: WSC 30389 123 56831
ASAM Dataset: EV_ECM20TFS0205G0906259F 001004
ROD: EV_ECM20TFS0205G0906259J.rod
VCID: 313FE88591ABBF42E0D-8065
VINID: 9E69EAAAA0D3A9A54008518520274044B7
No fault code found.
Readiness: 1110 0000
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 018 C HW: 02E 927 770 AS
Component: DQ250-6A MQB H54 5297
Revision: 06454104 Serial number: TFK01706160335 CVN: 000099EF
Coding: 0014
Shop #: WSC 05311 115 00065
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 1C612931E629222AA3B-8049
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 FM HW: 5Q0 614 517 AH
Component: ESC H62 0755
Revision: 00000000 Serial number: 61907000000236
Coding: 0FEC6B8F54222371477D070540CB69F0D62AC4E2E00296753842508842A9420000000012121212B835351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
ROD: EV_Brake1UDSContiMK100IPB_037_VW48.rod
VCID: 015F7845618BEFC250D-8055
1 Fault Found:
8210 - Databus
U1121 00 [10001001] - Missing Message
[FCAN: Allrad_03 message is not received]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 200
Mileage: 194370 km
Date: 2024.08.21
Time: 13:36:59
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 3Q0 959 435 Q HW: 3Q0 959 435 Q
Component: VWKESSYMQB 037 1400
Revision: 00037000 Serial number: 0577965047 Dataset Number: V03935321YJ 0001
Coding: 1F20200723
ASAM Dataset: EV_KessyHellaMQBAB 004055
ROD: EV_KessyHellaMQBAB.rod
VCID: 48C9A56102311E8AD73-801D
Rear lid opener control module:
Subsystem 1 - Part No SW: 3G0 962 243 HW: 3G0 962 243
Component: GEB.F.Heckoef H17 0812
Serial number: ;8001216
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 3Q0 959 760 D HW: 3Q0 959 760 B
Component: Sitzmemory H05 0024
Serial number: Y0006PKA28228 Dataset Number: V03935285VX 0001
Coding: 001000020000050081C481808080000000008181000000F400
ASAM Dataset: EV_SeatMemorPasseSide 002022
ROD: EV_SeatMemorPasseSide.rod
VCID: 3C21C9B146E9422A43B-8069
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 3G8 907 044 T HW: 3G8 907 044 T
Component: Climatronic H10 0221
Coding: 12020024104411011115500D0018592A
ASAM Dataset: EV_AirCondiBHTCMQB3rTranc 002004
ROD: EV_AirCondiBHTCMQB3rTranc_002_VW37.rod
VCID: 3E25C3B950F5503A6DF-806B
Air quality sensor:
Humidity sensor: exterior:
Rear air conditioning block 1:
Subsystem 3 - Part No SW: 11A 907 049 A HW: 11A 907 049 A
Component: E265 KPH SH H02 0183
Serial number: G04S01.11.2100972191
Coding: FFFFFF
1 Fault Found:
655621 - Temperature Sensor for Rear Left Seat
B1113 15 [00101111] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Mileage: 194370 km
Date: 2024.08.21
Time: 13:34:53
Unlearning counter according OBD: 40
Control Module Voltage: 11.900 V
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q1 937 084 B HW: 5Q1 937 084 B
Component: BCM MQBAB HO H44 0512
Serial number: 02102311001826 Dataset Number: V03935381P 0001
Coding: 000000000000000000000000000000000000000000000000000000000000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_BCMMQB 022001
ROD: EV_BCMBOSCH_022_VW37.rod
VCID: 3829D5A172D16E0AA73-806D
Wiper motor control module:
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 170615 042 0607
Serial number: 170629234856
Coding: 0F4DFD
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Component: G397_RLFSS H06 0002
Serial number: 22181601X81A955555A0
Coding: 02005D
Light switch:
Subsystem 3 - Part No SW: 3G8 941 633 HW: 3G8 941 633
Component: E1 - LDS MQB H01 0032
Serial number: 19 04 2017 10000901
Anti-theft alarm system sensor:
Subsystem 4 - Part No SW: 5Q0 951 172 A HW: 5Q0 951 172 B
Component: Sensor, DWA 005 0403
Serial number: 000000000ZL23010051V
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0314
Serial number: 00000000000070188699
Blower 1 for left front backrest:
Subsystem 6 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Component: SysNameFanLin 014 0101
Serial number: ESE0158736
Blower 1 for left front seat cushion:
Subsystem 7 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0096892
Blower 1 for right front backrest:
Subsystem 8 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0145994
Blower 1 for right front seat cushion:
Subsystem 9 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0146336
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 L HW: 5QA 919 298 A
Component: PLA 3.0 12K H07 0074
Serial number: 000308417617172 Dataset Number: V03935315EN 0001
Coding: 8A79267951
ASAM Dataset: EV_EPHVA2CAU3700000 009055
ROD: EV_EPHVA2CAU3700000_009_VW37.rod
VCID: 59EF7025A99B970278D-800D
2 Faults Found:
13637426 - Databus
U1123 00 [00001001] - Received Error Message
[ESP - ESP_21.ESP_Systemstatus - Fehlerspeicher auslesen]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 200
Mileage: 194370 km
Date: 2024.08.21
Time: 13:34:55
13688835 - Databus
U1123 00 [00001000] - Received Error Message
[Steuerger‰t f¸r Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 240
Mileage: 194370 km
Date: 2024.08.21
Time: 13:36:58
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 S HW: 3QF 907 572 A
Component: ACC BOSCH MQB H11 0780
Dataset Number: V12345678AA V315
Coding: 351F5FFBDFFFCF28979F813681500D80000000000099000032
ASAM Dataset: EV_ACCBOSCHVW416 003015
ROD: EV_ACCBOSCHVW416_003_VW41.rod
VCID: 47CBA65D0F2F11F2DE9-8013
6 Faults Found:
0803 - Databus
[FAULT_BV1_FEHLER]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 200
Mileage: 194370 km
Date: 2024.08.21
Time: 13:35:04
Control Module temperature: 27 ∞C
Voltage terminal 15-Voltage: 11.8 V
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.00 m/s≤
Adaptive distance regulation: status: ACC_irreversible error
2101 - Databus
[FAULT_ESP_STATUS_SYSTEM]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 200
Mileage: 194370 km
Date: 2024.08.21
Time: 13:34:55
Control Module temperature: 26 ∞C
Adaptive distance regulation: status: ACC_StandBy
2418 - Databus
[FAULT_KLR_TOUCH_ERROR]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 22
Reset counter: 239
Mileage: 193224 km
Date: 2024.07.28
Time: 12:41:33
Control Module temperature: 36 ∞C
Voltage terminal 15-Voltage: 12.8 V
1538 - Sensor for Automatic Distance Control
C110B F0 [00001000] - Limited Visibility
[FAULT_SENSOR_BLIND]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 218
Mileage: 192933 km
Date: 2024.07.27
Time: 16:03:37
Control Module temperature: 42 ∞C
Voltage terminal 15-Voltage: 13.7 V
Vehicle speed: 34.09 m/s
Longitudinal acceleration: -0.44 m/s≤
Adaptive distance regulation: status: ACC_activ_controlled
1542 - Sensor for Automatic Distance Control
[FAULT_SYSTEM_BLIND]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 218
Mileage: 192933 km
Date: 2024.07.27
Time: 16:03:37
2068 - Databus
[FAULT_TSK_IRREV_FAIL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 200
Mileage: 194370 km
Date: 2024.08.21
Time: 13:34:55
Voltage terminal 15-Voltage: 11.9 V
Adaptive distance regulation: status: ACC_reversible_error
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 C HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0130
Serial number: 25061741350001 Dataset Number: V03935290WM 0001
ASAM Dataset: EV_DRCONTITEMIC 001019
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 392FD0A549DB770258D-806D
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 3Q0 959 655 CP HW: 3Q0 959 655 CP
Component: Airbag VW21 006 0721
Revision: -------- Serial number: 003Z4PGADL1% Dataset Number: V03935283XG 0001
Coding: 98FCC0C0008000005C5400CF000800000065
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
ROD: EV_AirbaVW21TS6VW48X_VW37.rod
VCID: 0E45537920D580BADDF-805B
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 106 1040
Serial number: 3G0857705 0031T01500
Coding: 80000D
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 106 1032
Serial number: 3G1857706G0185R01460
Coding: 80000D
Crash sensor for side airbag: driver side:
Subsystem 3 - Part No SW: ----------- HW: 454 001 606 17
Component: SideSensor_Df 008 0887
Serial number: 357000000000507D3628
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 4 - Part No SW: ----------- HW: 454 001 806 17
Component: SideSensor_Pf 008 0887
Serial number: 358000000008D140C62J
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 5 - Part No SW: ----------- HW: 454 801 106 17
Component: SideSensor_Dr 301 0148
Serial number: 3510091305210000000U
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 6 - Part No SW: ----------- HW: 454 801 106 17
Component: SideSensor_Pr 301 0148
Serial number: 352002F2F52100000009
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 7 - Part No SW: ----------- HW: 454 801 406 17
Component: FrontSensor_D 304 0149
Serial number: 3550040279610000000%
Coding: 2D2D2D
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 KT HW: 5Q0 953 569 B
Component: Lenks.Modul 100 0265
Revision: FF035035 Serial number: 20170828500092 Dataset Number: V03935250KY 0001
Coding: 8410
ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
ROD: EV_SMLSVALEOMQBLRH.rod
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 3G0 920 791 D HW: 3G0 920 791 C
Component: KOMBI 406 4191
Coding: 07AD0898FE8C000C01887F0F3001000080000000
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_DashBoardVDDMQBAB 009058
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 2A0DFFE9BC7DCC9A217-807F
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 K HW: 5Q0 963 272 H
Component: STH-MQB 008 0080
Coding: 9309
Shop #: WSC 00015 115 00001
ASAM Dataset: EV_AuxilParkiHeateWOS 002018
ROD: EV_AuxilParkiHeateWOS.rod
Auxiliary heating remote control:
Subsystem 1 - Part No SW: 3Q0 963 513 HW: 3Q0 963 513
Component: R64 D208L 004 0401
Serial number: 00000000000000276932
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AR HW: 3Q0 907 530 C
Component: GW MQB High 518 5502
Serial number: 06071710802132 Dataset Number: V03935278KN 0001
Coding: 0B0B00347F015900DB00025E9C0F00010001070000000000000000000000
GVL: 015E3C0008000600C0FC80000006CC0010000000000200000030000000000000
ASAM Dataset: EV_GatewNF 013026
ROD: EV_GatewNF_VW37.rod
VCID: 7F5BFEBD177F9932269-802B
Generator:
Component: 4-00-03-00-04
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 1EA 959 442 E HW: 1EA 959 442 E
Component: MFL H03 0219
Serial number: 17036218123222100161
Coding: AF0B00
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 3Q0 915 181 B HW: 3Q0 915 181 B
Component: J367-BDMHella H10 9070
Serial number: 5131394104
Inverter for electrical outlet:
Subsystem 4 - Part No SW: 5Q0 907 155 C HW: 5Q0 907 155 C
Component: U13DCAC H26 0780
Serial number: 0066181
Analog clock:
Subsystem 5 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 111 1004
Serial number: 3003201700010095
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 17000160250002
Coding: 0800000000000000
ASAM Dataset: EV_ELVMarquMQBB 001007
ROD: EV_ELVMarquMQBB_VW37.rod
VCID: 71BF2885512BFF42A0D-8025
Address 36: Seat Mem. Drvr (J810) Labels:* None
Serial number: Y0006QFD15173 Dataset Number: V03935285VX 0001
Coding: 001000020000150081C481808080000000008181000000F400
ASAM Dataset: EV_SeatMemorDriveSide 002022
ROD: EV_SeatMemorDriveSide.rod
Address 3C: Lane Change (J1086) Labels:* Redir Fail!
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H07 0150
Serial number: 00000591782366 Dataset Number: V03935345YL 0001
Coding: 62954640
ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 2Q0 907 685 B HW: 2Q0 907 685 B
Component: HRE3_Kl15_Slv H07 0150
Serial number: 00000606636104
1 Fault Found:
2240558 - Databus
[databus error value received - ESP_33 - ESC_Verz_Reg_nicht_verfuegbar]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 194370 km
Date: 2024.08.21
Time: 13:36:57
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 L HW: 5Q0 959 593 F
Component: TSG FS003 0350
Serial number: YE007VFP28434 Dataset Number: V03935363WB 0001
Coding: 00359A20D200028200011000
ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001018
ROD: EV_DCU2DriveSideMAXHKLO.rod
VCID: 4ACD9F691C3DEC9AC17-801F
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5082
Dataset Number: 8V0909852AA 0001
Coding: 93070000
Shop #: WSC 00015 115 00319
ASAM Dataset: EV_SteerAssisMQB 015157
ROD: EV_SteerAssisMQB_015.rod
Address 47: Sound System (J525) Labels:| 3Q0-035-466.clb
Part No SW: 3Q0 035 465 HW: 3Q0 035 465
Component: MIB2_amp_P_VW H60 0440
Revision: 00000001 Serial number: VWZ8Z1HJD00RUVL Dataset Number: V03935264BQ 0001
Coding: 1284020001AA0A2AAA0000000000
ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001018
ROD: EV_AMPMst16C3Gen2ALPI_VW48.rod
VCID: 6B833AED730715929A1-803F
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 01071710801233 Dataset Number: V03935339UR 0001
Coding: 000000060100035207007F010A0000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 001010
ROD: EV_MultiModulContiVW48X_001.rod
VCID: 72BD2789542DC45A597-8027
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _
Component: Leimo links H02 0003
Coding: E02400
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _
Component: Leimo rechts H02 0003
Coding: E02400
2 Faults Found:
13705999 - Databus
U1123 00 [10001001] - Received Error Message
[Kamera_FDD_Funktionsstatus_Fehler received error status]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 200
Mileage: 194370 km
Date: 2024.08.21
Time: 13:35:31
13706000 - Databus
[Kamera_FDD_Eigenblend_Guete received error status]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 200
Mileage: 194370 km
Date: 2024.08.21
Time: 13:35:01
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 L HW: 5Q0 959 592 F
Component: TSG BFS003 0350
Serial number: YE007VF20444B Dataset Number: V03935358AV 0001
Coding: 00359020DE00028200011000
ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001018
ROD: EV_DCU2PasseSideMAXHKLO.rod
VCID: 49CFA065193BE782C8D-801D
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 5NA 035 022 D HW: 5NA 035 022
Component: MU-H-LND-EU H54 1367
Serial number: A846F0JS020395 Dataset Number: V03935262VW 0001
Coding: 02840201000000005111110200880A301F0106E4012004009F
ASAM Dataset: EV_MUHig4CGen2HBAS 001001
ROD: EV_MUHig4CGen2HBAS_VW37.rod
VCID: 3431E1916EB98A6A8BB-8061
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5G6 919 606 HW: 5G6 919 606
Component: ABT_High-2 H50 9130
Serial number: VWZ6ZJT1915518
Data carrier:
Subsystem 2 - Part No SW: V03 959 821 CG HW: -----------
Component: ECE 2024 --- 0350
Serial number: --------------------
Compact disc data bank:
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1016
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 5Q0 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000081630 Dataset Number: RDKS_TinyQ_ 1017
ASAM Dataset: EV_RDKBERU30 006001
ROD: EV_RDKBERU30_006_VW37.rod
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 N HW: 5Q0 907 383 N
Component: Anhaenger H27 0264
Revision: 8A001003 Serial number: 0446947174 Dataset Number: V03935259HF 0001
Coding: 0100000202000000
ASAM Dataset: EV_TrailFunctGener2Hella 001008
ROD: EV_TrailFunctGener2Hella_VW26.rod
VCID: 42DDB749240D34DA097-8017
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 5Q0 907 556 C HW: 5Q0 907 556
Component: Areaview 2 H13 0608
Serial number: C854707JG069231 Dataset Number: ----------
Coding: 01840200E70F200004314817
ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
ROD: EV_CamSysRVAV2ARCE2MQBAB_006_VW37.rod
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 5Q0 959 107 Q HW: 5Q0 959 107 C
Component: HDSG-Modul H12 0265
Revision: -------- Serial number: 31344982200000 Dataset Number: V03935262CS 0001
Coding: 02A8
ASAM Dataset: EV_DeckLidCONTIAU736 001016
ROD: EV_DeckLidCONTIAU736_VW48.rod
VCID: 46D5AB59082508FA25F-8013
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 2Q0-980-653.clb
Part No SW: 2Q0 980 653 D HW: 2Q0 980 653
Component: MQB MFK 3.0 H16 1421
Serial number: E80320003220200 Dataset Number: V03935411EY 0001
Coding: 0004019821FAC02888DF14001020004000218000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 007042
ROD: EV_MFK3ValeoMQB_007_VW27.rod
VCID: 3635DB9978C5987AB5F-8063
3 Faults Found:
1135140 - Databus
[APS_03_US_Fehler_HS]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 40
Mileage: 194370 km
Date: 2024.08.21
Time: 13:34:58
1135139 - Databus
[APS_03_US_Fehler_VS]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 40
Mileage: 194370 km
Date: 2024.08.21
Time: 13:34:58
1123173 - Databus
[ESP_21_ESP_Systemstatus]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 40
Mileage: 194370 km
Date: 2024.08.21
Time: 13:34:57
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 5Q0 959 595 L HW: 8W1 959 595 D
Component: TSG HFS005 0350
Serial number: YE007VBO10863 Dataset Number: V03935306SB 0001
Coding: 000490200100028000001000
ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001018
ROD: EV_DCU2RearDriveMAXHKLO.rod
VCID: 4CC199711649F2AAF3B-8019
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS005 0350
Serial number: YE007VBO13878 Dataset Number: V03935306RQ 0001
ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001018
ROD: EV_DCU2RearPasseMAXHKLO.rod
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 D HW: 4M0 907 594
Component: SAD_STG_1 011 0003
Dataset Number: V03935218DJ 0001
Coding: 208040748202
ASAM Dataset: EV_SunRoofCONTIAU736 004008
ROD: EV_SunRoofCONTIAU736_004.rod
VCID: 372BD69D7FCF6172AE9-8063
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LEDModLeftMELCOAU736 001004
ROD: EV_LEDModLeftMELCOAU736_VW37.rod
VCID: 16753B191805787A95F-8043
1 Fault Found:
1061 - Supply Voltage for Logic
C121F 13 [00001000] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 234
Mileage: 193637 km
Date: 2024.08.08
Time: 21:32:38
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H09 0003
ASAM Dataset: EV_LEDModRightMELCOAU736 001004
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 234
Mileage: 193637 km
Date: 2024.08.08
Time: 21:32:38
Address 8126: Trq distrib RearL axle (J492) Labels: 08E-907-554.clb
Part No SW: 08E 907 554 H HW: 08E 525 130
Component: 4Motion H05 0125
Serial number: 012WEOT
Coding: 00010100
ASAM Dataset: EV_TorquSplitLeftMAGNA 001005
ROD: EV_TorquSplitLeftMAGNA.rod
VCID: 3333E28D6BB78D52921-8067
5 Faults Found:
24832 - Control Module for AWD Torque Distribution
P1D24 00 [00101111] - Incorrect Installation
[Dtc_ecuvar_mismatch]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Snapshot Record Number: 16
Number Of Identifiers: 18
DID: 64768
Major Version Number: 6
Minor Version Number: 0
Bugfix Version Number: 2
Patch version number: 1
Occurrence Counter TOC: 3
Occurrence Counter SLC: 1
Occurrence Counter TNCTOC: 0
Occurrence Counter SLF: 0
Occurrence Counter SFF: 0
Core Service State: 4
Error Event Number: 70
Event Triggers Current Backup Function: false
Origin System Up Counter: 1
Most Recent System Up Counter: 0
Origin Operation Cycle Counter: 0
Most Recent Operation Cycle Counter: 4
Error specific Freeze Frame raw data: 63 14 10 00 01 00 FF 01 00 00 00 06 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Oil temperature: 31.81 ∞C
Clutch Input Speed: 0.0 /min
Estimated Transferred Clutch RPM: 0 /min
Battery voltage: 14.05 V
Vehicle speed: 0.00 km/h
Actuator current: 0.00 A
Actuator angle: 1.97 ∞
Engine speed: 0.0 /min
Bridge Temperature: 30 ∞C
KL15 Status SW: 0
KL15Status HW: 1
KL15 Status Comb: 1
System Condition of error decision manager: 232
Status CSM: 1
stTC: 0
stTCExtdSec: 0
16384 - Control Module for AWD Torque Distribution
P1CEF 00 [00101111] - Rear Differential Oil Change Required
[Oil_worn_60_kw_h_exceeded]
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 194370 km
Date: 2024.08.21
Time: 13:34:53
DID: 64768
Occurrence Counter TOC: 1
Error Event Number: 88
Origin System Up Counter: 44
Origin Operation Cycle Counter: 4
Most Recent Operation Cycle Counter: 0
Error specific Freeze Frame raw data: 83 15 10 00 08 01 00 00 01 0B 00 00 83 FF FA FF 00 00 00 00 00 00 00 00 00 00 00 00
Oil temperature: 23.69 ∞C
Battery voltage: 12.16 V
Actuator current: 0.01 A
Actuator angle: -1.95 ∞
Bridge Temperature: 22 ∞C
KL15 Status SW: 1
KL15Status HW: 1
KL15 Status Comb: 1
System Condition of error decision manager: 233
Status CSM: 1
stTC: 4
stTCExtdSec: 275
24592 - Control Module for AWD Torque Distribution
P1D23 00 [00101111] - Differential Friction Class Missing
[DTC_CC_CLASSIFICATION_NOT_DONE]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
DID: 64768
Error Event Number: 90
Event Triggers Current Backup Function: true
Origin System Up Counter: 3
Most Recent System Up Counter: 3
Error specific Freeze Frame raw data: A3 25 10 00 08 01 00 00 88 0B 00 00 87 FF 00 00 00 00 00 00 00 80 00 00 00 00 00 00
Oil temperature: 31.19 ∞C
KL15 Status SW: 0
KL15Status HW: 1
KL15 Status Comb: 1
Status CSM: 1
stTC: 7
stTCExtdSec: 0
24588 - Clutch Position Not Learned
P080A 00 [00101111] - -
[Inital_calibration_missing]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
DID: 64768
Error Event Number: 91
Origin System Up Counter: 2
Most Recent System Up Counter: 1
Error specific Freeze Frame raw data: B3 25 10 00 00 00 00 00 08 00 00 00 87 FF 00 00 00 00 00 00 00 80 00 00 00 00 00 00
Oil temperature: 31.44 ∞C
KL15 Status SW: 0
KL15Status HW: 1
KL15 Status Comb: 1
Status CSM: 1
stTC: 7
stTCExtdSec: 0
12563 - Databus
U1121 00 [00101111] - Missing Message
[Brake_control_unit_to_eps_40]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 194370 km
Date: 2024.08.21
Time: 13:38:40
DID: 64768
Error Event Number: 113
Origin System Up Counter: 22801
Origin Operation Cycle Counter: 5
Error specific Freeze Frame raw data: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Oil temperature: 30.50 ∞C
Battery voltage: 12.05 V
Actuator current: -0.00 A
KL15 Status SW: 1
KL15Status HW: 1
KL15 Status Comb: 1
Status CSM: 1
stTC: 4
stTCExtdSec: 275
Address 8127: Trq distrib RearR axle (J492) Labels: 08E-907-554.clb
Serial number: 012WDYM
Coding: 00010100
ASAM Dataset: EV_TorquSplitRightMAGNA 001005
ROD: EV_TorquSplitRightMAGNA.rod
5 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
DID: 64768
Oil temperature: 32.25 ∞C
Battery voltage: 13.99 V
Actuator angle: 1.72 ∞
Bridge Temperature: 32 ∞C
KL15 Status SW: 0
KL15Status HW: 1
KL15 Status Comb: 1
Status CSM: 1
stTC: 0
stTCExtdSec: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 194370 km
Date: 2024.08.21
Time: 13:34:53
DID: 64768
Error specific Freeze Frame raw data: 83 15 10 00 08 01 00 00 01 0B 00 00 7A 00 FB FF 00 00 00 00 00 00 00 00 00 00 00 00
Oil temperature: 23.00 ∞C
Battery voltage: 12.10 V
Actuator current: -0.01 A
Actuator angle: 1.91 ∞
KL15 Status SW: 1
KL15Status HW: 1
KL15 Status Comb: 1
Status CSM: 1
stTC: 4
stTCExtdSec: 275
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
DID: 64768
Error specific Freeze Frame raw data: A3 25 10 00 08 01 00 00 88 0B 00 00 71 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00
Oil temperature: 31.63 ∞C
KL15 Status SW: 0
KL15Status HW: 1
KL15 Status Comb: 1
Status CSM: 1
stTC: 7
stTCExtdSec: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
DID: 64768
Error specific Freeze Frame raw data: B3 25 10 00 00 00 00 00 08 00 00 00 71 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00
Oil temperature: 31.69 ∞C
KL15 Status SW: 0
KL15Status HW: 1
KL15 Status Comb: 1
Status CSM: 1
stTC: 7
stTCExtdSec: 0
12563 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 194370 km
Date: 2024.08.21
Time: 13:39:39
DID: 64768
Origin System Up Counter: 28716
Oil temperature: 30.94 ∞C
Battery voltage: 11.99 V
KL15 Status SW: 1
KL15Status HW: 1
KL15 Status Comb: 1
Status CSM: 1
stTC: 4
stTCExtdSec: 275
End----(Elapsed Time: 02:31, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
Friday,30,August,2024,13:59:28:11868
VCDS Version: 24.7.0.0 (x64) HEX-V2 CB: 0.4643.4
www.Ross-Tech.com
VIN: WVWZZZ3HZPE5024xx License Plate:
Mileage: 7276km-4521mi Repair Order:
Chassis Type: 3H-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 23 2B 36 3C 42 44 47 4B
52 5F 65 6C 6D 75 A5 A9 BB BC CA D6 D7 8126 8127
VIN: WVWZZZ3HZPE5024xx Mileage: 7276km-4521miles
01-Engine -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
23-Brake Booster -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: Malfunction 0010
75-Telematics -- Status: Malfunction 0010
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-DNFG) Labels: None
Part No SW: 3G0 906 259 M HW: 06K 907 425 M
Component: R4 2.0l TFS H80 0003
CVN: 839836B5
Coding: 092540322466050B30040000000000000000000000000000
ASAM Dataset: EV_ECM20TFS0203G0906259M 001005
ROD: EV_ECM20TFS0203G0906259L.rod
VCID: 3635DB9978C5987AB5F-8062
VINID: 9E69EAAAA0D8AA0545002107103A48DAE7
4 Faults Found:
Readiness: 0000 0000
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0DL 300 014 C HW: 0GC 927 711 H
Component: GSG DQ500 H06 3704
Revision: 00H06V13 CVN: 851E7413
Coding: 0014
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021_001_VW36.rod
VCID: 2B03FAEDB387D592DA1-807E
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 3Q0 614 517 AK HW: 5Q0 614 517 BR
Component: ESC H82 0993
Revision: 00000000 Serial number: 61282000000110
Coding: 0DEC7B94D1203B6E477B070760C769B0DE8BDCE2E00696753842558852A849080003010312121212B435351919323200
ASAM Dataset: EV_Brake1UDSContiMK100VWR 001005
ROD: EV_Brake1UDSContiMK100VWR_VW48.rod
VCID: 78A915A13251AE0A673-802C
1 Fault Found:
Revision: 00037000 Serial number: 0603040039 Dataset Number: V03935330VK 0001
Coding: 1F20200723
Shop #: WSC 05311 115 00319
VCID: 48C9A56102311E8AD73-801C
Subsystem 1 - Part No SW: 3G0 962 243 C HW: 3G0 962 243 C
Component: GEB.F.Heckoef H17 0906
Serial number: 25915633
Part No SW: 3G8 907 044 Q HW: 3G8 907 044 Q
Coding: 14020024200114011115100C8010D936
Shop #: WSC 00015 115 08193
VCID: 3B23CAAD43E745124A1-806E
Air quality sensor:
Subsystem 2 - Part No SW: 4H0 907 658 C HW: 4H0 907 658 C
Component: G935 MuFu H06 0012
Serial number: B4458B2D00PAG0MUFU04
Subsystem 3 - Part No SW: 11A 907 049 B HW: 11A 907 049 B
Component: E265 KPH SH H02 0184
Serial number: G06S31.08.2200973530
Coding: FFFFFF
5 Faults Found:
Part No SW: 5Q0 937 086 CK HW: 5Q0 937 086 BR
Component: BCM PQ37BOSCH 040 0400
Revision: -------- Serial number: J53F0708221764 Dataset Number: V03935368JF 0001
ASAM Dataset: EV_BodyContrModul1UDSBosc 021001
ROD: EV_BCMBOSCH_021_VW37.rod
VCID: 05576C5575A3C3E26C5-8050
Subsystem 1 - Part No SW: 3G1 955 119 D HW: 3G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 220315 046 0607
Serial number: 220322113637
Coding: 0E4DDD
Subsystem 2 - Part No SW: 5Q0 955 555 A HW: 5Q0 955 555 A
Component: RLHSS 054 0207
Serial number: S6Y22M08D05H04M20S34
Coding: 0008DD
Light switch:
Serial number: 27 04 2022 10000711
Serial number: 000000000ZL2215800JZ
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000002680583
Humidity sensor: interior:
Steering Column Switch:
Subsystem 7 - Part No SW: 5Q1 953 521 MT HW: 5Q1 953 569 K
Component: Lenks.Modul H24 0190
Serial number: 0100150820220C300763
Part No SW: 5QA 919 298 K HW: 5QA 919 298 A
Component: PLA 3.0 12K H10 0075
Serial number: 000150057322237 Dataset Number: V03935375US 0001
Coding: 8271167851
Shop #: WSC 05311 115 00090
VCID: 58E97521D2918E0A473-800C
3 Faults Found:
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 AA HW: 2Q0 907 572 D
Component: ACCCONTIMQB H09 0396
Dataset Number: V03935375VL 0001
Coding: 32057FD35CFF8728749F812481408780000000000000000064
ASAM Dataset: EV_ACCMRRCONTIVW376 003018
ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
VCID: 73B3228D2B37CD52521-8026
4 Faults Found:
Serial number: 30082241350106 Dataset Number: V03935328WN 0001
VCID: 392FD0A549DB770258D-806C
Part No SW: 5QF 959 655 AP HW: 5QF 959 655 AP
Component: Airbag VW22 015 0755
Revision: -------- Serial number: 003019EPH2LX95 Dataset Number: V03935349HH 0001
Coding: 98FCC0C00C8000005C5400CF000C40000065
ASAM Dataset: EV_AirbaVW22TS6VW48X 001036
ROD: EV_AirbaVW22TS6VW48X.rod
VCID: 241111D1DE591AEA1BB-8070
Component: BeltPretRevFL 106 1062
Serial number: 3G8857705F0237W00380
Coding: 802006
Component: BeltPretRevFR 106 1062
Serial number: 3G8857706F0252W00441
Coding: 802006
Subsystem 3 - Part No SW: ----------- HW: 454 002 008 22
Serial number: 357000000000A6D0C16K
Coding: 2D2D2D
Subsystem 4 - Part No SW: ----------- HW: 454 001 908 22
Serial number: 35800000000F13DC036Q
Coding: 2D2D2D
Subsystem 5 - Part No SW: ----------- HW: 454 802 008 22
Serial number: 35100FBAA1820000000N
Coding: 2D2D2D
Subsystem 6 - Part No SW: ----------- HW: 454 801 908 22
Serial number: 3520045748F20000000C
Coding: 2D2D2D
Subsystem 7 - Part No SW: ----------- HW: 454 801 408 22
Serial number: 35500B40F8E20000000O
Coding: 2D2D2D
Driver's side crash data pedestrian protection:
Subsystem 8 - Part No SW: ----------- HW: 454 802 905 22
Component: PedP_Sensor_D 304 0149
Serial number: 22800D4EE4E1F0000005
Coding: 2D2D2D
Passenger's side crash data pedestrian protection:
Subsystem 9 - Part No SW: ----------- HW: 454 802 905 22
Component: PedP_Sens_P_2 304 0149
Serial number: 229000EF74E1F000000/
Coding: 2D2D2D
Center pedestrian protection crash sensor:
Subsystem 10 - Part No SW: ----------- HW: 454 802 805 22
Component: PedP_Sensor_C 304 0149
Serial number: 2300092F616200000003
Coding: 2D2D2D
Driver's side crash data pedestrian protection 2:
Subsystem 11 - Part No SW: ----------- HW: 454 002 507 22
Component: PedP_Sens_D_2 008 0887
Serial number: I0M00000000901F4B060
Coding: 2D2D2D
Passenger's side crash data pedestrian protection 2:
Subsystem 12 - Part No SW: ----------- HW: 454 002 507 22
Component: PedP_Sensor_P 008 0887
Serial number: I0N00000000201F4B06.
Coding: 2D2D2D
6 Faults Found:
Part No SW: 3G0 920 320 C HW: 3G0 920 320 C
Component: KOMBI 524 6220
Dataset Number: V03935376JY 0001
Coding: 04AC3898FE8C00080180624F1001000880700003
Shop #: WSC 00015 015 00040
ASAM Dataset: EV_DashBoardVDDMQBA0 001048
ROD: EV_DashBoardVDDMQBA0_001_VW37.rod
VCID: 1D672435FD332B22545-8048
4 Faults Found:
Part No SW: 3Q0 907 530 AR HW: 3Q0 907 530 E
Component: GW MQB High 524 5502
Serial number: 22082210802227 Dataset Number: V03935364QX 0001
Coding: 0B0900047F015B00FB1088BE980F00010001070000000000000000000000
GVL: 014E3C100800060840DC80008082CC0010000000000200000030000000000000
VCID: 7F5BFEBD177F9932269-802A
Generator:
Component: 5-00-14-00-04
Subsystem 2 - Part No SW: 1EA 959 442 F HW: 1EA 959 442 F
Serial number: 17038315102082202828
Coding: 2F2B00
Component: J367-BDMHella H11 9070
Serial number: 7758930106
Component: U13DCAC H27 0810
Serial number: 3335101
1 Fault Found:
1282 - Supply voltage
U1011 00 [00001000] - Voltage too Low
[Versorgungsspannung - unterer Grenzwert unterschritten]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 61
Mileage: 7276 km
Date: 2024.08.11
Time: 00:09:33
Terminal 30 power supply: 8.4 V
Terminal 15: OFF
Address 23: Brake Booster (J539) Labels:. 5QE-909-059.clb
Part No SW: 3Q0 909 059 AF HW: 3Q0 909 059 D
Component: EBKV H09 0209
Serial number: BPA085150822013
Coding: 4103C500400000B5D65A6BAD000049922449922400
ASAM Dataset: EV_BrakeBoostG2BoschVW48X 015024
ROD: EV_BrakeBoostG2BoschVW48X_015.rod
VCID: 7BA30AAD036785120A1-802E
26 Faults Found:
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H07 0020
Serial number: 22000207836018
ASAM Dataset: EV_ELVMarqMQBA0 002002
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 3333E28D6BB78D52921-8066
Part No SW: 3Q0 959 760 E HW: 3Q0 959 760 E
Component: Sitzmemory H07 0026
Serial number: Y0007VGN36435
Coding: 001000020000050081C281808080000000008181000000F440
VCID: 3D27C4B55DF34B22745-8068
2 Faults Found:
Component: HRE3_Kl15_Mst H06 0150
Serial number: 14520017912529 Dataset Number: V03935334PN 0001
Coding: 52A54640
Component: HRE3_Kl15_Slv H06 0150
Serial number: 14520017890919
4 Faults Found:
Serial number: YE007VHS0810A Dataset Number: V03935363WB 0001
Coding: 003F5B42D200028000001000
VCID: 4ACD9F691C3DEC9AC17-801E
1 Fault Found:
Address 44: Steering Assist (J500) Labels:| 5WA-907-14X-V1.clb
Part No SW: 5WA 907 145 Q HW: 5WA 907 145 C
Component: BASGEN1MQB37 502 1063
Serial number: 01426080 Dataset Number: V03935375UD 0001
Coding: 01000100010000010001020101000100000001010100
ASAM Dataset: EV_SteerAssisBASGEN1MQB37 010058
ROD: EV_SteerAssisBASGEN1MQB37_010.rod
2 Faults Found:
Address 47: Sound System (J525) Labels:* None
Part No SW: 3G0 035 466 D HW: 3G0 035 466 D
Component: AMPeth16C H03 3831
Serial number: A1130J00078754 Dataset Number: V03935352H 0001
Coding: 24090000000000000000000000000000000000000000000000
ASAM Dataset: EV_AMPEthMQB 001005
ROD: EV_AMPEthMQB_VW48.rod
VCID: 26150BD9A865E8FA05F-8072
1 Fault Found:
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 3Q0 907 338 F HW: 3Q0 907 338 L
Component: FCM MQB High 006 0370
Serial number: 28082211600537 Dataset Number: V03935347XG 0001
Coding: 000000070F0004D207106F04020300000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 003003
ROD: EV_MultiModulContiVW48X_003.rod
VCID: 3829D5A172D16E0AA73-806C
Antenna for short-range communication:
Subsystem 1 - Part No SW: 3V0 959 121 A HW: 3V0 959 121 A
Component: R350 NFCTGS 401 0109
Serial number: 0000000000B556C5010C
Antenna 2 for short-range communication:
Subsystem 2 - Part No SW: 3G0 980 611 HW: 3G0 980 611
Component: J524 NFCMIKO H09 0062
Serial number: 32200000000001681553
4 Faults Found:
Serial number: YE007VHN3577C Dataset Number: V03935358AV 0001
Coding: 003F5142DE00028000001000
VCID: 49CFA065193BE782C8D-801C
1 Fault Found:
Address 5F: Information Electr. (J794) Labels:| 3G5-035-MIB-HGH3.clb
Part No SW: 3G1 035 816 B HW: 3G5 035 816
Component: MU-O-ND-EU H57 0836
Serial number: WG8LGM010922000 Dataset Number: V03935374QT 0001
Coding: 24831000000000000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB 001002
ROD: EV_MUOIMQB_001_VW48.rod
Subsystem 1 - Part No SW: 5G6 919 606 C HW: 5G6 919 606 C
Component: ABT_High-2 381 9304
Serial number: VWZ6ZHA2393996
Data carrier:
Subsystem 2 - Part No SW: V03 959 817 SM HW: -----------
Component: EUR 2022/23 --- 7065
4 Faults Found:
Component: RDKBERU30 H06 0011
Serial number: 40000000632092 Dataset Number: V03935358KR 0001
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Component: RVC Compact H18 0231
Dataset Number: V03935320P 0001
Coding: 0184030162002017000040
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
ROD: EV_CamSysRVRVCPANAMQBAB_006_VW48.rod
Part No SW: 5WC 959 107 A HW: 5WC 959 107 A
Component: HDSG-Modul H05 0433
Revision: -------- Serial number: A2-C767-1160-8 Dataset Number: V03935376GA 0001
Coding: 5808
ASAM Dataset: EV_DeckLidCONTIAU536 001002
ROD: EV_DeckLidCONTIAU536_VW42.rod
VCID: 4FFB8E7DE75FC9B2969-801A
1 Fault Found:
Address 75: Telematics (J949) Labels:* None
Part No SW: 5WA 035 284 G HW: 5WA 035 284 B
Component: OCUGen3High H20 0143
Serial number: 0000000207VIHJ9 Dataset Number: V03935357NU 0001
Coding: 024830001968AC209025460161502E07
ASAM Dataset: EV_OCUGen3High 003007
ROD: EV_OCUGen3High_003_VW27.rod
2 Faults Found:
Component: MQB MFK 3.0 H16 1401
Serial number: EA1567404222360 Dataset Number: V03935374AF 0001
Coding: 00000888216EC020089E10001030004000418000000000000000000000000000
3 Faults Found:
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 3G8 907 159 A HW: 4K0 907 159
Component: SAS-GEN 2.5 H08 0001
Serial number: 220617290003
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X_003_VW37.rod
VCID: 323DE78994AD845A997-8066
Serial number: YE007VGU16096 Dataset Number: V03935357KU 0001
Coding: 000A51420100028000001000
VCID: 4CC199711649F2AAF3B-8018
Serial number: YE007VGT36026 Dataset Number: V03935357KN 0001
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Dataset Number: V03935356RV 0001
Coding: 608040748312
ASAM Dataset: EV_SunRoofCONTIAU736 009011
ROD: EV_SunRoofCONTIAU736_009_VW37.rod
VCID: 75B71C952543D3627C5-8020
Part No SW: 992 941 572 AA HW: 992 941 572 A
Component: LED1L H08 9002
ASAM Dataset: EV_LLPGen3LKEBODPO68X 001003
ROD: EV_LLPGen3LKEBODPO68X_001_VW27.rod
VCID: 629D57C984CD54DA297-8036
1 Fault Found:
Component: LED1R H08 9002
ASAM Dataset: EV_LLPGen3RKEBODPO68X 001003
1 Fault Found:
Serial number: 013387N
Coding: 00010100
2 Faults Found:
Serial number: 01337E4
Coding: 00010100
2 Faults Found:
End----(Elapsed Time: 02:36, VBatt start/end: 11.7V/11.6V. VIgn 11.6V)-----
SW:3Q0-614-517-AK HW:5Q0-614-517-BR --- ABS Brakes
Component:ESC H82 0993, Coding:0DEC7B94D1203B6E477B070760C769B0DE8BDCE2E00696753842558852A849080003010312121212B435351919323200
EV_Brake1UDSContiMK100VWR,001005,EV_Brake1UDSContiMK100VWR_VW48.rod
Friday,30,August,2024,14:00:02:11868
VCDS Version: Release 24.7.0 (x64) Data version: 20240715 DS356.3
IDE00252-Brake system vacuum pump,5 ,1
IDE00820-Activating and deactivating all development messages,0 ,1
IDE01763-Dimming,activated ,1
IDE02332-Deactivate production mode,Deactivating ,3
IDE03493-Driver's door status,activated ,1
IDE03659-Roller test bench mode,Manual activation: possible ,1
IDE04456-Brake disk drying,Medium ,1
IDE04508-Hydraulic brake booster,8 ,1
IDE04643-Overboost in brake system,activated ,1
IDE04645-Electromechanical parking brake,not activated ,1
IDE04774-Vehicle and trailer stabilization,not activated ,1
IDE04871-Dynamic starting assist,normal ,1
IDE04939-Tire Pressure Monitoring System (TPMS),Conditions not correct or request sequence error,1
IDE04944-Brake pedal evaluation,activated ,1
IDE04949-Engine drag torque control,activated ,1
IDE04951-Brake Boost,4 ,1
IDE04952-Braking torque boost for distance regulation,3 ,1
IDE05055-Hydraulic brake assistant,normal ,1
IDE05057-Brake prefill,activated ,1
IDE05161-Straight ahead brake stabilization,activated ,1
IDE05263-AUTO HOLD functionality,not activated ,1
IDE05264-AUTO HOLD increase threshold: reduced tensioning force,0 %,1
IDE05265-AUTO HOLD increase threshold: full tensioning force,10 %,1
IDE05286-Expanded electronic differential lock,Standard ,1
IDE05711-Automatic application during engine stalling,activated ,1
IDE06137-IDE04772-Monitoring of functional lights-Indicator light in the button for electromech. parking brake,7 ,2
IDE06137-IDE05333-Monitoring of functional lights-Indicator light in AUTO HOLD button,7 ,2
IDE06139-AUTO HOLD slippage recognition,activated ,1
IDE06425-Dynamometer mode: functional,not activated ,1
IDE06505-Electromechanical parking brake: delay level,6 ,1
IDE07006-Tire pressure monitoring display: tire selection,Conditions not correct or request sequence error,1
IDE07565-ABS in lower speed range,activated ,1
IDE07848-Thresholds for brake performance,activated ,1
IDE12030-Rough road optimization,activated ,1
MAS00122-Electronic Stability Program,not activated ,1
MAS00970-Running manufacturer number,activated ,1
MAS01180-AUTO HOLD functional status,Last setting ,1
MAS01299-Offroad,0 ,1
MAS02080-XCP calibration protocol,not activated ,1
MAS02138-Hill-start assistant,normal ,1
MAS02666-Seat belt buckle scan,activated ,1
MAS07300-Monitoring infotainment control unit,Security access required,1
MAS09008-MAS00988-Plausibility check-Reverse gear,activated ,3
MAS09008-MAS09009-Plausibility check-Neutral gear sensor,activated ,3
MAS09008-MAS10668-Plausibility check-Clutch movement,activated ,3
MAS11606-Electromechanical parking brake: emergency braking,activated ,1
ENG118148-Developer_Function_1,Security access required,1
ENG122612-Developer_Function_100,Security access required,1
ENG122613-Developer_Function_101,Security access required,1
ENG122615-Developer_Function_103,Security access required,1
ENG122616-Developer_Function_104,Security access required,1
ENG122617-Developer_Function_105,Security access required,1
ENG122618-Developer_Function_108,Security access required,1
ENG130301-Developer_Function_121,Conditions not correct or request sequence error,1
ENG118149-Developer_Function_2,Security access required,1
ENG118200-Developer_Function_3,Security access required,1
ENG118201-Developer_Function_4,Security access required,1
ENG127702-Developer_Function_5,Security access required,1
ENG122844-ENG101574-dimming_characteristic_1-X1,0 ,12
ENG122844-ENG99557-dimming_characteristic_1-X2,10 ,12
ENG122844-ENG102140-dimming_characteristic_1-X3,50 ,12
ENG122844-ENG102936-dimming_characteristic_1-X4,100 ,12
ENG122844-ENG103548-dimming_characteristic_1-X5,220 ,12
ENG122844-ENG113992-dimming_characteristic_1-X6,253 ,12
ENG122844-ENG99777-dimming_characteristic_1-Y1,6 ,12
ENG122844-ENG100480-dimming_characteristic_1-Y2,6 ,12
ENG122844-ENG100773-dimming_characteristic_1-Y3,8 ,12
ENG122844-ENG100631-dimming_characteristic_1-Y4,12 ,12
ENG122844-ENG102174-dimming_characteristic_1-Y5,80 ,12
ENG122844-ENG113993-dimming_characteristic_1-Y6,100 ,12
ENG122845-ENG101574-dimming_characteristic_2-X1,0 ,12
ENG122845-ENG99557-dimming_characteristic_2-X2,10 ,12
ENG122845-ENG102140-dimming_characteristic_2-X3,50 ,12
ENG122845-ENG102936-dimming_characteristic_2-X4,100 ,12
ENG122845-ENG103548-dimming_characteristic_2-X5,220 ,12
ENG122845-ENG113992-dimming_characteristic_2-X6,253 ,12
ENG122845-ENG99777-dimming_characteristic_2-Y1,6 ,12
ENG122845-ENG100480-dimming_characteristic_2-Y2,6 ,12
ENG122845-ENG100773-dimming_characteristic_2-Y3,8 ,12
ENG122845-ENG100631-dimming_characteristic_2-Y4,12 ,12
ENG122845-ENG102174-dimming_characteristic_2-Y5,80 ,12
ENG122845-ENG113993-dimming_characteristic_2-Y6,100 ,12
Elapsed Time: 00:16
SW:08E-907-554-H HW:08E-525-130 --- Trq distrib RearL axle
Component:4Motion H05 0125, Coding:00010100
EV_TorquSplitLeftMAGNA,001005,EV_TorquSplitLeftMAGNA.rod
Friday,30,August,2024,13:59:44:11868
IDE00820-ENG278519-Activating and deactivating all development messages-Dev Msg Rx Test Bench,reception of testbench message disabled ,1
IDE00820-ENG278512-Activating and deactivating all development messages-Dev Msg Tx Private Can,disable transmission of developer message on private CAN ,1
IDE00820-ENG278533-Activating and deactivating all development messages-Dev Msg Tx Public Can,disable transmission of developer message on public CAN ,1
IDE00820-ENG278447-Activating and deactivating all development messages-Dev Msg Tx Test Bench,disable transmission of testbench message (private CAN only) ,1
IDE00820-ENG278546-Activating and deactivating all development messages-Xcp Rd Wr Enable,Xcp disabled ,1
IDE03339-ENG278503-Friction classes (customer service)-Class_gearbox,6808 ,3
IDE03339-ENG278454-Friction classes (customer service)-Class_version,21 ,3
IDE06869-installation position,Variant selection - CAN 2.0 L ,1
IDE16464-Data transfer after exchange of control module,03 06 00 02 01 82 57 56 57 5A 5A 5A 33 48 5A 50 45 35 30 32 34 37 34 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1A 98 15 02 5A 00 00 00 22 00 00 00 04 00 00 00 01 00 00 00 00 00 00 03 24 00 00 00 00 1C 6E 00 00 00 22 00 00 00 04 00 00 00 01 00 00 03 24 00 00 1C 6E 00 00 03 D9 00 00 AD F2 00 00 34 EE 00 00 09 AB 00 02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 3E C3 47 09 ,512
Elapsed Time: 00:02
SW:08E-907-554-H HW:08E-525-130 --- Trq distrib RearR axle
EV_TorquSplitRightMAGNA,001005,EV_TorquSplitRightMAGNA.rod
Friday,30,August,2024,13:59:53:11868
IDE03339-ENG278503-Friction classes (customer service)-Class_gearbox,6386 ,3
IDE06869-installation position,Variant selection - CAN 2.0 R ,1
IDE16464-Data transfer after exchange of control module,02 06 00 02 01 82 57 56 57 5A 5A 5A 33 48 5A 50 45 35 30 32 34 37 34 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 18 F2 15 02 B8 00 00 00 29 00 00 00 05 00 00 00 01 00 00 00 00 00 00 03 24 00 00 00 00 1C 6E 00 00 00 29 00 00 00 05 00 00 00 01 00 00 03 24 00 00 1C 6E 00 00 03 D9 00 00 B3 04 00 00 33 9B 00 00 09 C9 00 02 FF 43 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0D 35 31 9A ,512
Elapsed Time: 00:02
Saturday,31,August,2024,19:16:02:11868
www.Ross-Tech.com
VIN: WVWZZZ3CZJE025658 License Plate:
VIN: WVWZZZ3CZJE025658 Mileage: 194819km-121054miles
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
15 Faults Found:
20646 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
P0030 00 [00100111] - Malfunction / Open Circuit
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 194819 km
Date: 2024.08.31
Time: 19:13:04
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 21 °C
Intake air temperature: 24 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 12.226 V
Engine: operating status: ES
STATE_LS_SAE[1]: INI
T_AST_SAE: 0 s
MAP_MES_SAE: 102 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
TTIP_MES_LS_UP[1]: -2048.0000 °C
TEG_DYN_LS_UP[1]: 22.4750 °C
15170 - Engine Oil Temp. Sensor (G8)
P0198 00 [00100111] - Signal too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 194819 km
Date: 2024.08.31
Time: 19:13:06
T_AST_SAE: 0 s
FAC_TPS_1_SAE: 16.406250 %
FUP_H_SAE: 760.0 kPa
15376 - Fuel Pressure Regulator Valve (N276)
P2294 00 [10100111] - Open Circuit
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 194819 km
Date: 2024.08.31
Time: 19:13:02
ECU_STATE: ENG_STOP
High-pressure system: status: VCV_OPEN
STATE_CRK_STST: CRK_STST_PAS
TFPA: -14 °C
TFU_HPP: 9.00 °C
FUP_H_SAE: 740.0 kPa
15015 - Turbocharger Bypass Valve Control Circuit
P0033 00 [00100111] - Malfunction / Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 194819 km
Date: 2024.08.31
Time: 19:13:02
T_AST_SAE: 0 s
FUP_H_SAE: 750.0 kPa
15270 - Camshaft Timing Adj. Bank1 (N205)
P1528 00 [00100111] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 194819 km
Date: 2024.08.31
Time: 19:13:03
T_AST_SAE: 0 s
15267 - Bank1; Exhaust Cam Adjustment Valve 1 (N318)
P1050 00 [00100111] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 194819 km
Date: 2024.08.31
Time: 19:13:03
T_AST_SAE: 0 s
15381 - Cam Adjustment Actuator A; Cylinder 1
P11A1 00 [00100111] - Elec. Malf. or Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 194819 km
Date: 2024.08.31
Time: 19:13:01
CAM_VCP[EX_1]: 0.000 °
CTR_VVL_LIH_DEAC: 0
CTR_VVL_LIH_ACT: 0
CTR_VVL_SWI_DC: 0
T_SWI_VVL_ACR: 0.0 ms
NR_CYL_FIRST_VVL_SWI: 0
15383 - Cam Adjustment Actuator A; Cylinder 3
P11A9 00 [00100111] - Elec. Malf. or Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 194819 km
Date: 2024.08.31
Time: 19:13:01
CTR_VVL_LIH_DEAC: 0
CTR_VVL_LIH_ACT: 0
CTR_VVL_SWI_DC: 0
15384 - Cam Adjustment Actuator A; Cylinder 4
P11AD 00 [00100111] - Elec. Malf. or Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 194819 km
Date: 2024.08.31
Time: 19:13:01
CTR_VVL_LIH_DEAC: 0
CTR_VVL_LIH_ACT: 0
CTR_VVL_SWI_DC: 0
15382 - Cam Adjustment Actuator A; Cylinder 2
P11A5 00 [00100111] - Elec. Malf. or Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 194819 km
Date: 2024.08.31
Time: 19:13:01
CTR_VVL_LIH_DEAC: 0
CTR_VVL_LIH_ACT: 0
CTR_VVL_SWI_DC: 0
15401 - Cam Adjustment Actuator B; Cylinder 1
P11A3 00 [00100111] - Elec. Malf. or Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 194819 km
Date: 2024.08.31
Time: 19:13:01
CTR_VVL_LIH_DEAC: 0
CTR_VVL_LIH_ACT: 0
CTR_VVL_SWI_DC: 0
15403 - Cam Adjustment Actuator B; Cylinder 3
P11AB 00 [00100111] - Elec. Malf. or Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 194819 km
Date: 2024.08.31
Time: 19:13:01
CTR_VVL_LIH_DEAC: 0
CTR_VVL_LIH_ACT: 0
CTR_VVL_SWI_DC: 0
15404 - Cam Adjustment Actuator B; Cylinder 4
P11AF 00 [00100111] - Elec. Malf. or Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 194819 km
Date: 2024.08.31
Time: 19:13:01
CTR_VVL_LIH_DEAC: 0
CTR_VVL_LIH_ACT: 0
CTR_VVL_SWI_DC: 0
15402 - Cam Adjustment Actuator B; Cylinder 2
P11A7 00 [00100111] - Elec. Malf. or Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 194819 km
Date: 2024.08.31
Time: 19:13:01
CTR_VVL_LIH_DEAC: 0
CTR_VVL_LIH_ACT: 0
CTR_VVL_SWI_DC: 0
15423 - Turbocharger Boost Control Position Sensor Circuit
P2565 00 [10100111] - Signal too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 194819 km
Date: 2024.08.31
Time: 19:13:01
Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0]: 00000000
Charge air pressure control valve uncond voltage sensor: 4.9902 V
Charge air pressure control valve position: target value: 0.00 %
Charge air pressure control valve position: actual value: 0.00 %
Charge air pressure control valve activation pulse duty factor: 0.00 %
Charge air pressure control valve voltage: position closed: 4.3604 V
STATE_BPA[0]: OPM
Coding: 0014
1 Fault Found:
8210 - Databus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 210
Mileage: 194819 km
Date: 2024.08.31
Time: 19:13:03
Coding: 1F20200723
Air quality sensor:
Coding: FFFFFF
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Mileage: 194819 km
Date: 2024.08.31
Time: 19:13:00
Control Module Voltage: 12.100 V
655623 - Temperature Sensor for Rear Right Seat
B1114 15 [00101111] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Mileage: 194819 km
Date: 2024.08.31
Time: 19:13:00
Coding: 0F4DFD
Coding: 02005D
Light switch:
Alarm horn:
Coding: 8A79267951
1 Fault Found:
13637426 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 210
Mileage: 194819 km
Date: 2024.08.31
Time: 19:13:00
4 Faults Found:
0803 - Databus
[FAULT_BV1_FEHLER]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 210
Mileage: 194819 km
Date: 2024.08.31
Time: 19:13:06
Control Module temperature: 40 °C
Voltage terminal 15-Voltage: 12.1 V
Longitudinal acceleration: 0.00 m/s²
2101 - Databus
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 210
Mileage: 194819 km
Date: 2024.08.31
Time: 19:13:00
0928 - Databus
U1122 00 [00001000] - Implausible Message
[FAULT_STOPPING_DISTANCE_CONTROL_NOT_AVAILABLE]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 250
Mileage: 194819 km
Date: 2024.08.31
Time: 19:13:00
2068 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 210
Mileage: 194819 km
Date: 2024.08.31
Time: 19:13:00
Coding: 80000D
Coding: 80000D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 8410
Coding: 9309
Generator:
Coding: AF0B00
Analog clock:
Coding: 62954640
1 Fault Found:
2240558 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 194819 km
Date: 2024.08.31
Time: 19:13:02
Coding: 93070000
Coding: E02400
Coding: E02400
2 Faults Found:
13705999 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 210
Mileage: 194819 km
Date: 2024.08.31
Time: 19:12:59
13706000 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 210
Mileage: 194819 km
Date: 2024.08.31
Time: 19:13:00
Data carrier:
Coding: 02A8
3 Faults Found:
1135140 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 40
Mileage: 194819 km
Date: 2024.08.31
Time: 19:13:01
1135139 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 40
Mileage: 194819 km
Date: 2024.08.31
Time: 19:13:01
1123173 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 40
Mileage: 194819 km
Date: 2024.08.31
Time: 19:13:00
Coding: 00101000
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
DID: 64768
Occurrence Counter SFF: 12
Most Recent Operation Cycle Counter: 51
Error specific Freeze Frame raw data: B3 25 10 00 00 00 00 00 08 00 FF 00 4D FF 00 00 00 00 00 00 00 80 00 FF 00 00 00 00
Oil temperature: 31.69 °C
Actuator angle: 1.72 °
Bridge Temperature: 30 °C
KL15 Status SW: 0
KL15Status HW: 1
KL15 Status Comb: 1
Status CSM: 1
stTC: 7
stTCExtdSec: 0
12563 - Databus
Freeze Frame:
Fault Priority: 0
Fault Frequency: 14
Reset counter: 40
DID: 64768
Occurrence Counter SLC: 14
Most Recent System Up Counter: 502
Oil temperature: 0.00 °C
Battery voltage: 0.00 V
Actuator angle: 0.00 °
Bridge Temperature: 0 °C
KL15 Status SW: 0
KL15Status HW: 0
KL15 Status Comb: 0
System Condition of error decision manager: 0
Status CSM: 0
stTC: 0
stTCExtdSec: 0
Coding: 00010100
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
DID: 64768
Occurrence Counter SFF: 11
Most Recent Operation Cycle Counter: 46
Error specific Freeze Frame raw data: B3 25 10 00 00 00 00 00 08 00 FF 00 E4 00 00 00 00 00 00 00 00 80 00 FF 00 00 00 00
Oil temperature: 31.44 °C
Actuator angle: 1.97 °
KL15 Status SW: 0
KL15Status HW: 1
KL15 Status Comb: 1
Status CSM: 1
stTC: 7
stTCExtdSec: 0
12563 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 13
Reset counter: 40
Mileage: 194370 km
Date: 2024.08.21
Time: 13:38:40
DID: 64768
Occurrence Counter SLC: 13
Oil temperature: 30.50 °C
Actuator angle: -1.95 °
KL15 Status SW: 1
KL15Status HW: 1
KL15 Status Comb: 1
Status CSM: 1
stTC: 4
stTCExtdSec: 275
End----------(Elapsed Time: 02:36, VBatt start/end: 12.2V/12.2V)-----------
