iichel
- Netherlands
- Passat B8
Keeping you posted...
Current 3Q0... AA gateway supports addresses
Center prop shaft doesn't need to be changed
Front transfer box doesn't seem to need a change
Drive shafts do need to be changed
Wiring seems easy...
Swapping haldex seems to be medium difficulty (Passat B8)
Need to think about breather pipes
Will first dry-test the control units before making a swap
Parts involved:
Parts involved:
- Diff
- 1x 08E525010x (I took the Arteon version ending H, golf mk8 hatchback is F)
- Drive shafts L + R for Passat (Golf uses different ones! 5WA501203 /A and 5WA501204 /A)
- 1x 5NA501203A (left, remember, left is odd. for part numbers with L/R designations)
- 1x 5NA501204A
- 2x WHT005437A bolts
- Bolts haldex to subframe
- 3x N10720201
- Bolts prop shaft to rubber disc
- 3x WHT005179
- Seal boot
- 2x N90857202 (need to drill the floor to remove rear bolts)
- Cover on Haldex bottom in orange
- 1x 5H0825268
- 3x N90737107
- Wiring
- Harmonica pipe
- 2x 80A973711 T11
- 1x 8D0973834 coupling original for CAN/+15
- 1x 6N0973855 coupling extra power wires (2,5mm2)
- 1x 6N0973755 coupling extra power wires (2,5mm2)
