shovelhd
- Western MA
It's in the manual.
Hold the trip reset while turning the ignition on. Follow the prompts.
Doesn't go bad... Rock itDoes oil go bad. Have a little liquid moly stored on the self from 7500 miles ago. Doing an oil change tomorrow... got fresh 6 liters or whatever it is but should i use the stuff on the shelf first?
It's in the manual.
I had the inspection due and oil change due at the same time. Did what you said and it only reset the oil change reminder. Should I do it again? And since this is the random stupid question thread what is the wrench button in the overhead thing by the rear view mirror?
Are the pins that hold the paddle shifters available anywhere for purchase?
Thanks!!
I wouldn't - unless you are in the middle of Death Valley and there's no dealer around.Ok the use this? Need some collant and i asked for g13 and they said this was fine.... at first pep boys then autozone
It also depends if you are under warranty. There's a good chance that it'll do no harm, but you may run into issues if you have a coolant related warranty claim.
Next time if you only need a cup or so just add distilled water. And resize the pictures
Mud
