Here's my silly question also related to keys. I bought my car used and it would seem the original owner only surrendered one of the fobs. Is it safe to assume that since there's no key hole (like there was on my MKV) on the driver's door, that it's impossible to get a valet (read: fob-less) key? I'm guessing if I want a backup, it has to be a fully programmed FOB.
If you push the actual key into the slot on the door handle it should open via the transponder in the fob. Also if your battery dies in your remote it will still be able to communicate with the car if you hold it up next the the steering Column by the VW symbol
