uberdot
- Ten Forward
- Silver 2017 6MT
I use like 3 layers of wax on the contact points before I put mine onbest way to protect the roof paint when using a roof rack, where the rubber pads meet the roof?
real question.....what if the fluid level was low to start with?The Motive power filler is great but it's overkill for a DSG service. For top fill, all you need is the funnel suggested above and a 24mm socket for the filter. You'll need to measure what drained out. For OEM bottom fill, you'll need a kit like this.
That's why I bottom fill. This is my third DSG transmission, so that kit I referenced has paid for itself many times over.real question.....what if the fluid level was low to start with?
This is why I'm going to bottom fill. The top fill method is if you want to replace exactly what you took out. My suspicion is that the fluid level is not exactly correct to start with so I'm inclined to start over with a good measurement by doing the level setting procedure. Probably overkill, but that's how I roll.real question.....what if the fluid level was low to start with?
I am having trouble understanding why top or bottom fill would matter if you are just referencing the amount you took out? My concern about it being low would still apply?
I see Diggs mentioned drain out excess, that part helps me.....is the issue people overfill and don't check/adjust levels?
Stealership trip or DIY? I’ve never done one and my backup VR6 isn’t road ready yetWell, sooner or later you'll need a cam cradle reseal.
