Mk7 GTI Catch Can Options - edit: Bought one! Brutally honest review unfolding...
I'm seriously considering a catch can for my GTI. Seems intelligent as I drive the ever living hell out of my GTI - I see the following available options:
IE: http://www.performancebyie.com/ie-mk7-recirculating-catch-can-kit
Pros: Appears you can reuse your engine cover, appears to not delete the PCV valve.
Cons: Draining? Dipstick? Specious valving? OMFG price.
APR: https://www.goapr.com/products/catch_can_mqb_ea888.html
Pros: Integrates nicely, appears easy to drain.
Cons: No dipstick, cheap connections, requires the APR intake to work (!?!?!?!), placement in bay is suspect. Does it REALLY require that intake?
CTS: http://www.ctsturbo.com/cart/products/CTS_Turbo_MK7_TSI_Catch_Can_Kit-4753-0.html
Pros: Good hose routing, quality components, has a dipstick.
Cons: Can you re-use the engine cover? removal for draining appears to be a PITA.
BFI: http://blackforestindustries.com/blog/2014/10/27/mqb-mk7-2-0t-gen-3-catch-can/
Pros: Cheap.
Cons: Bad experience with quality from this vendor (who offered to make it right, but by then too late), really piss poor hose routing, specious baffling
other potential contenders:
42 Draft Designs: Don't see a Mk7 option as a kit.
Current ranking (if the engine cover is usable post install):
CTS - engine cover man!
IE - wow expensive
BFI - if I -have- to
APR - NOT getting that intake
Wildcard: 42 Draft Designs -if- there's a kit???
Maybe running: Forge?
What else is out there? What would you spend your $$$ on? CTS is the STRONGEST contender IF I can put the engine cover back on...
Pros: Cheap.
IE - wow expensive
