ZoomnRx
'99 VR6
- Hampton Roads, VA
- 2019 GTI SE
Probably a dumb question but I’d rather have the answer. I bought a TCR exhaust for my 2019 GTI. @GTI Jake will that bolt up directly to your oem fitment resonated midpipe?
Thanks @GTI Jake for clarifying. I wasn't sure if your mid pipe would extend all the way to the muffler. @bradbusa 's video helps give a great visual. Since I have a 2019 GTI, bolting up the TCR isn't as straight forward so I was looking for an option that was easier since I haven't had any luck finding a 2018 stock cat back locally.
Everything I read was that it is 65 mm because the 2018 GTI still used the 65 mm piping from the mk7. I’ll measure and share with the group for education when I get it in hand.I was under the impression TCR was 60mm
Bolted right up on my 18 without a problem.Everything I read was that it is 65 mm because the 2018 GTI still used the 65 mm piping from the mk7. I’ll measure and share with the group for education when I get it in hand.
TCR is 65mm. Mine is attached with a clamp, no adapter.15-18 is 65mm & 19-21 is 60mm on normal GTI.
TCR on the other hand is gonna be up to someone who owns one to confirm
Just for the record on the thread. Those measurements are correct as expected from Jake. Couldn't find a clamp or reducer to connect it myself for a 65 mm to 60 mm connection so I'm getting it welded on later this week.15-18 is 65mm & 19-21 is 60mm on normal GTI.
@GTI Jake i remember seeing one of your videos (can’t find it) where you explained exactly where to cut the the exhaust for the OEM fitment Midpipe.
https://golfmk7.com/forums/index.ph...to-get-the-sound-you-want.345407/post-7817330This is going to sound dumb, but wanted to ask and make sure. I was able to pick up an AWE DP and Switchpath. I want to get a resonator welded in. Is the Vibrant 17950 the one I want and will it fit in a 7.5R? The shop I talked to was concerned that it might not fit because of the driveshaft.
