I had the same "issue" as you. That P0642D is actually called K0642D "K" stands for Customer Update.Hi mr-fix,
Thanks for your reply!
Maybe my question wasn't clear, so let me try again.
On mibsolutions.one the latest (complete) firmware version I can find is P0635D, see image below.
For version P0640D and P0642D there is only a patch witch contains a file called "delphibin.ifs", see image below, or is this something else?
For as far as I can tell there is no complete firmware package for version P0642D or am I missing something?
Thanks for your help!
I had the digital display retrofit with coding (component protection not disabled, had it done with vas5054a and odis). would updating my firmware brick this?Yes, 0478 is the latest one for units with 04xx firmwares.
If your unit is stock (no patching, modifications, outside dealership activations...) you should be fine.
no idea what exactly was done, so really can't tell.I had the digital display retrofit with coding (component protection not disabled, had it done with vas5054a and odis). would updating my firmware brick this?
Are you on 17.2.1?Thank you so much for this. I have a 2018 golf gte , and suddenly having problems with CarPlay. VW no more helpful than I could work out for myself, so very happy to have found infotainment updates here
I installed
MST2_EU_VW_ZR_P0480T_3G0919360QQ
Which I believe is the latest? Everything is working fine and the update was easy,
Sadly I thought this would fix CarPlay after checking every setting, factory resets, hard resets, network resets, new cables - everything!
But still the same error , connection failed, ensure phone is unlocked. It is and all settings support it. Content and privacy restrictions off. Siri on.
So I guess I’ll have to wait for a new iOS now - I’m on 17.1.2 and it sounds like a lot of people have the same issue.
But I’ve learned a lot and updated my car, so thank you Mr Fix!
Yes and I’ve tried absolutely everything methodically. So frustrating! I see I wrote the iOS wrong before, but yes 17.2.1Are you on 17.2.1?
Do you use telegram? If so what’s your username?I'm trying to do a G11 to G13 conversion. I am confused on how to edit the metainfo2.txt file.
My current train is: MHI2_US_VWG11_P3261
and I am converting to: MHI2_US_VWG13_P3659_2
These are the instructions from the wiki. I initially edited the file to add these two lines:
SupportedTrains = "MHI2_US_VWG11_P3261"
#SupportedTrains = "MHI2_US_VWG13_*"
The install stops at the first screen (Please wait 10 minutes), I left it like that for over an hour, no change. Can someone help let me know exactly what to put in the text? This is the only step of the process that I am questioning, although it's possible something else is wrong altogether.
https://github.com/harman-f/MHI2_MIB2_AIO_FW_Update_Template/wiki/G11-to-G13-conversion
