KyACRASH
- Fort Walton Beach, FL
- 2015 GTI 6MT, 04 R32
sent you a DMDo you use telegram? If so what’s your username?
So before I get too far, I use AA and not Carplay, and my similar issue happened when I went to MIB 2.5 but...Yes and I’ve tried absolutely everything methodically. So frustrating! I see I wrote the iOS wrong before, but yes 17.2.1
I had assumed the infotainment needed updating to support the iOS, but the problem seems to be the iOS itself. The same phone and set up worked just fine before
Are you saying you got this in a Golf? That would be news, I don’t think I’ve ever seen that before.
This is in My Atlas, I may do the GTI next. Unfortunately, little to no one does this kind of stuff in the Atlas community so I have to look to the Golf and Tig forums for help. Having done the MIB2 swap in my GTI has helped me understand a little. These are the clocks I used, I was very lucky to pick them up NEW & cheap from another Atlas owner.Are you saying you got this in a Golf? That would be news, I don’t think I’ve ever seen that before.
Generally speaking, large software train changes are not recommended. Certain jumps are possible, but it comes down to specific hardware on the board and whatnot. As far as your question goes, whilst I don't have specific experience with 2GM units, I think attempting to jump to the P08XXD software train would be risky.I have an MIB2 STD Delphi 2GM 035 844 A
Train Version: MST2_US_VW_P0120D and I need to get to 876B or 876C minimum. I Installed the AID digital cockpit (all working 100%) but I want to be able to use the Car setting menu to change the gauges that sit inside the 2 clocks. (Active info display menu settings)
Helper suggests I can do it, but is this a big risk or a simple upgrade. Just follow the regular update instructions and will be OK?
Thanks !
https://mib-helper.com/index.php?train=MHI2_ER_VWG11_S2125_1+#detailsHi everyone!
I have a 2016 e-Golf, and I'm trying to update the firmware on the MIB2 unit using manuals mostly found here, but I can't identify which update version I have to download from mibsolutions.one
My current SW version:
MHI2_ER_VWG11_S2125_1 (0343)
Available downloads for MHI2:
Which one should I choose?
Thanks!
Thank you! I also did check this tool but somehow did not find the exact version I was looking for...
The car is a 2016 e-golf, i think it never got any software updates. The SW is very slow compared to any other mib 2 high I've seen before, maybe an update can solve this. Other than that, I have no issues currently. The lag is what really kills me.@Narzis Is there something you are trying to fix by updating the firmware? If you are not having any problems it's not worth the trouble of updating. Later software might have a bug that is a problem for you.
