SugarMouth
- Nevada
Littco L450 Arrived!
I'll have Jeff from UM do the tuning. Should have some feedback in a couple weeks.
https://www.facebook.com/thelittleturbocompany/
Specs:
Pic #2 Side by side . Stock IS38 thrust washers vs. upgraded. If you want to run 29 psi reliably then you need to upgrade from stock. 144% larger than stock and better designed thrust bearing.
Pic #3-4 Was balanced to less than .3g.
Pic #5 Collar on the left is the stock IHI. On the right Littco has their modified one to use with their thrust bearings. These are custom made solely to work along side the thrust bearings and retain the stock backplate and bearing housing.
Pic#6 Is a Littco customer's dyno with Littco tuning. This is flywheel @ roughly 25psi.
Pic#7 is Littco customer's dyno with Littco tuning. This is at the wheel @ roughly 25psi.
Pic#8 My car on 91 octane stock fuel system with L450. Had a bit of knock retard from shitty fuel and the reason for the drop up top. 28psi.
Pic#9 Improved thrust bearing design with three oil feeds. Tested at 2.8bar.
Thread on hybrids offered by Littco >HERE<
Specs:
- 52mm 7+7 compressor wheel.
- 52mm turbine with OE blade profile.
- Upgraded thrust bearings.
littco said:Main IS38 hybrids we offer:
IS38X:
Stock spec'd IS38 with clipped turbine
Cnc machined compressor cover
Slow speed and VSR balance below 0.65g
Price is dependant on new or exchange
L430 Supercore:
Upgraded core, 50mm compressor wheel, clipped turbine, and compressor cover.
This is designed as a basic upgrade to the IS38 where by the original turbine housing, actuator and DV are used and user swappable.
£750 ( aprox $990 )
L450 Hybrid:
52mm OE profiled turbine
CNC machined housings
IS38 Actuator
DV&Muffler
400whp&450Bhp at C1.7bar
£1250 ( aprox $1650 )
L500 Hybrid:
54mm Custom large shaft turbine wheel
54mm Compressor wheel.
CNC machine housings
IS38 Actuator
DV&Muffler
Balancing as above.
500bhp@1.9bar
£1850 ( aprox $2400 )
L5656 Hybrid:
This is our new hybrid, yet to be fully tested. We have developed a 9 bladed turbine wheel using the same large shaft as the L500. This turbine is 56mm and will be used with out 56mm compressor we have tested to over 600bhp.
CNC housings
Balancing as above.
We will be doing a lot of testing over the coming month to see how the wheel compares to the existing 54mm wheel in various setups.
Anticipated power C550bhp
£2080 (aprox $2800)
