AZGTI2
- Phoenix, AZ
Have you changed your plugs to the Denso IKH24 with .024 gap?
Yes sir. Done when IS38 install
If you are only boosting 22 PSI then something's wrong man. Do you have a mechanical boost gauge?
There is no MAF on this car...
Did he mean MAP? That would make more sense and lean toward the sensor on the throttle body pipe being bad or you do have a boost leak.
Unfortunately, no. I suffered indecision paralysis in regards to this and ended up with nothing. I'm not sure I am only hitting 22 psi, but that is what I was told the MAP is maxed out at
Sorry if we covered this, do you have VAGCOM? If so log requested vs. actual boost pressure.
The map is going to only read 22 psi. That is why u need a mechanical boost gauge. The tune tricks the computer to see less boost to lean it out to make more power. The most basic way to do this. if you were untuned the map would be accurate.
